V2 beta Aug-1-2008 available now
 1-12  13-32
1839.13 In reply to 1839.12
A definite improvement Michael! great stuff!
Compare the inside surfaces.
V1 shell.
V2 shell
1839.14
Michael,
I'm impressed with the progress so far in V2.
However, one area where I find the workflow kind of difficult to get used to is the lack of layers. Will this functionality be added? (sorry if this has been mentioned before)
I'm just used to being able to group modelling construction components (curve, etc) in a layer as well as certain parts of a model.
Keep up the good work.
Regards,
Alan
1839.15 In reply to 1839.14
Ok,
I've just seen the thread " A scale model car" now if that can be achieved with MOI 1, then I guess its my workflow that needs to be updated.
I don't want to hijack this thread so I'll ask my question in the other thread.
Regards,
Alan
1839.16 In reply to 1839.1
Thank you very much :)
Tom
1839.17 In reply to 1839.15
Great stuff Michael. Some surfaces that wouldn't join or fillet using the previous V2 beta, now work fine.
I'm really looking forward to seeing some layers and a construction/work plane in upcoming releases.
~Kevin~
1839.18 In reply to 1839.17
Tyglik
That "first use" boolean bug only seems to be happening the very first time you do a boolean after opening MoI.
Subsequent, new, booleens set ups, while MoI is still open, do not seem to be affected.
(Sorry if that was what you were saying.)
Brian
1839.19 In reply to 1839.18
Curve Array Query.
Is there some logic I need to know to explain the different results between the "None" and "freeform" settings ?
Brian
EDITED: 30 Dec 2008 by BWTR
1839.20
Torolf
1839.21 In reply to 1839.19
You would see more of the logic behind these options if your object to array was rectangular in shape.
It's explained quite well Here in the online help.
1839.22 In reply to 1839.19
Yes, there is a clear logic behind. It has to do with a rotation of object to array during its sliding along a curve:
Freeform: Objects are rotated in three dimensions as they are arrayed along the path curve.
None: The objects do not rotate as they are arrayed, but remain in their original orientation.
Flat: Flat will only do rotations about the world Z axis (not a consistent up-direction relative to the construction plane, though. But it is already on the wishlist).
Petr
1839.23 In reply to 1839.22
Thanks.
Think it needed those particular screen shots to get it to sink in.
Brian
1839.24 In reply to 1839.12
I've playing around with the new beta (the newest one) and unfortunately I've noticed a lot of weird behaviors in almost all the complex operations (boolean, trim, join, fillet, merge). I kept getting extra planar surfaces in the middle of fillets, missing patches when trying to join two surfaces, and in general, the sensation that the app is struggling more than usual in doing his calculations. Looks like the new library has got more bugs than expected. Anyway, the Shell command seems to have improved without drawbacks!
Daniele
"The darker the night, the closer the dawn."
(Buddhist Proverb)
1839.25
I don't normally mess with beta releases (of anything), but this one... Math functions and 'extent, count' on array? Nice!!! :)
-Nick
All right, looks like I have zeroed in on the problem here, I should be able to make a new beta tonight that is fixed up.
1839.27 In reply to 1839.1
Thanks, Michael ...
Feet and inches works like a charm!
I hope for Rhino 4 layer and linetype compatibility in the future ... Fluid movement between MoI and Rhino is important to me.
I do find MoI generally more fluid for a lot of modeling ...
cheers,
eric
1839.28 In reply to 1839.4
Hi Paolo,
> "typing in numeric expressions"
> It works fine with the circles command.
> With lines i typed 2+2 space 5 space 0 enter,
> nothing happend.
Yes, like Petr mentioned the expressions were for single-value entries (like circle radius, offset distance, etc...) and not for x,y,z point coordinates.
But for the updated Aug-4 beta I have added some initial support for expressions for points as well.
The way it works is if your decimal point separator is not a , character then you can separate the coordinates by commas like: 2+2,5,0
Otherwise a second method is to put ( ) parenthesis around each coordinate, like: (2+2)(5)(0).
Currently the way you originally tried with pieces separated by spaces will not work. I also want to support spaces inside the expressions themselves so that is a more difficult one to support. But I'll try to take a look and see if I can add that in.
1839.29 In reply to 1839.14
Hi Alan,
Yup, this is definitely an area that is going to get added for v2.
It looks like I will probably be focusing attention on it just after I get back from SIGGRAPH.
It's a pretty in-depth area that will involve a lot of UI work, so it will probably take a little while before it is complete, like it will probably stretch out over a couple of months and a few beta releases.
But it is definitely planned to be a major focus area for v2, I just haven't quite gotten started on it yet.
1839.30 In reply to 1839.17
Hi Kevin,
Aside from just bug fixes for this beta Join has a new approach for its tolerance measurement, where for larger objects it will scale up the joining tolerance (the maximum distance that edges are allowed to be apart before they will be glued together) to be relative to the size of the object's bounding boxes.
That can help a lot with joining objects that are of a larger unit size.
These will definitely be coming! I actually wanted to get a construction plane mechanism in for this release but I just did not manage to find enough time to squeeze it in yet.
1839.31 In reply to 1839.24
Hi Daniele,
> than expected.
Just wanted to double-check with you - all of this seems to have been related to a single bug, but which was in a function which was used pretty heavily by those complex operations.
Did the Aug-4 release correct all these problems? Or do you still have a sense that things are not right?
1839.32 In reply to 1839.31
yes, the new 4th August beta is working fine for me, so far. Although I haven't yet had the chance to intensively test it with a heavy modeling project, the "first time" bug still hasn't showed up. I assume that fixing that single bug pretty much fixed all those weird behaviours once and (hopefully) for all.
Thanks for the feedback, as always!
Cheers Daniele
(Buddhist Proverb)
Show messages:  1-12  13-32
