Object name while OBJ exporting
All  1-3  4-6
1832.4 In reply to 1832.3
Hi Luca,
> Ok, if you confirm me that changing "object" with "filename"
> don't broke the OBJ file, I'll do that.
Yup, that should work fine to edit the OBJ file in a text editor, it will not break anything to just change those names.
> I'm not asking for that.... take ALL the time you want!
All done! :)
It was very easy to do since I already had some other programs set up (like SeparateOBJ) to scan through an OBJ and edit certain lines.
If you run the attached RelabelOBJ.exe program, it will ask you for a file name, and then it will go through and replace all the object names to be based off the file's own name instead of just "object".
So for instance if you have a file named my_file.obj, if you run the RelabelOBJ.exe program on it, all the object names will be turned from just "object1", "object2", etc... into "my_file1", "my_file2", etc...
Hopefully that will help out? Please let me know if it doesn't do what you need.
1832.5 In reply to 1832.4
Thanks a lot!
You are the best.
Do the same things manually work.... but now is better|
Luca
1832.6 In reply to 1832.5
Hi Luca, you're welcome!
Also I have now fixed the problem where selection is lost when you export to a mesh file format. In the next v2 beta the selection will be restored after the export is complete.
Show messages: All  1-3  4-6
