Bolts - Any way to create a macro-scipt ?
All  1-2  3-4
1823.3 In reply to 1823.1
Hi PaQ - here is a "QuickCircle" script for you which will place a circle by a single point pick.
To install, unzip the attached QuickCircle.zip to get 2 files (one .htm and one .js file) - copy these to the \commands subfolder inside of MoI's main installation folder, and then go to Options / Shortcut keys and set up a new shortcut key with QuickCircle as the command. You can then run the new command by pushing that shortcut key.
This command draws a circle of a particular radius, placing the circle just with a single click for its center point. The circle will align itself to surfaces if the point you picked is on a surface.
I left the default at 1.0, if you want to change the default to 0.1, you can edit the default="1.0" in the QuickCircle.htm file. But you can change the radius in the edit box.
Also after you pick a point, this command will keep running so that you can click down several points to place additional circles while inside the same command.
Hopefully that may be more convenient for you for placing large quantities of circles along surfaces?
1823.4 In reply to 1823.3
It's simply PERFECT !
Many many thanks Michael, your support is amazing !
Show messages: All  1-2  3-4
