smooth joint
1806.1
Please take a look in my attachment file
How do I make the middle line smooth?
-Thanks-Olga
1806.2 In reply to 1806.1
Hi Olga - normally you would use fillet, but it will probably have difficulties along a boundary like that where the curvature flips direction from kind of concave to convex.
The other tool for making things smooth is blend.
To use blend in this situation, you first need to open up some space - I did this by drawing in one line and then mirroring it like so:
Then select your surfaces, run Edit/Trim and select the lines as the cutting objects. Pick the inside pieces as the parts to discard, that will end up with this:
Now select a matching pair of edges and run Construct/Blend to make a smooth piece between them. Repeat with the lower edges and then you can use Edit/Join to glue the pieces together:
1806.3 In reply to 1806.1
A curve line is always smooth by nature ;)
So your object is smooth by essence
As nurbs are tensile surfaces between curves your object is also naturaly smooth:)
Now you can change the form of the "profil" as you want
Or just select your middle line and use function Transform/ fillet with 0.3 by example
So jonction between 2 wings part will be softy :)
ps Michael show you a more elaborated process ;)
EDITED: 22 Jul 2008 by PILOU
Size: 13.1 KB, Downloaded: 17 times, Dimensions: 219x331px
1806.4 In reply to 1806.2
Hi Michael
Thank you very much.
I did line trim and blend - it worked really well
I also tried freeform curve trim and blend and it did too.
I appreciate your assistance.
Olga
