Radius vs. Diameter
All  1-3  4-10
1803.4 In reply to 1803.1
Hi Tom, I've added a moi.ini switch for this for the next v2 beta. There will be a new entry under the [Commands] section:
[Commands]
UseDiameterDefault=n
You can switch that to y to make it default to Diameter for all radial type commands that use radius/diameter options. That should work better than updating the script, because you can just do it once and not have to re-do it on every release.
The new UseDiameterDefault option will get added into the moi.ini file the first time you run a radius/diameter type command. If you open up the moi.ini file before running such a command it won't be in there yet, but you can just add it in as a new line in that case.
1803.5 In reply to 1803.4
Works great, Thanks!!!
1803.6 In reply to 1803.4
Radius / diameter in functions like Circle?
1803.7 In reply to 1803.6
Yes, like in circle, I kept making my designs using radius when I wanted diameter :)
Tom
1803.8 In reply to 1803.6
Yup, this controls the default used in several radial-type commands such as Circle, Sphere, Cylinder, Cone, also one variety of Arc.
Currently you can switch these commands to use a diameter value by clicking on the "Radius" label, there is a kind of little "cycle" arrow on it.
Normally it defaults to Radius, this change allows you to set the default to Diameter instead.
1803.9 In reply to 1803.8
OK ;)
1803.10
I will find this tweak useful also!
Marc
Show messages: All  1-3  4-10
