> Radius / diameter in functions like Circle?
Yup, this controls the default used in several radial-type commands such as Circle, Sphere, Cylinder, Cone, also one variety of Arc.
Currently you can switch these commands to use a diameter value by clicking on the "Radius" label, there is a kind of little "cycle" arrow on it.
Normally it defaults to Radius, this change allows you to set the default to Diameter instead.
