actions tree and quote editor
All  1  2-8
18.2 In reply to 18.1
> actions tree
Probably not for V1 - I want to keep the V1 release focused on doing all the basic drawing stuff as smoothly as possible, so that you can draw things the way that you want the first time. But there is some possibility that it might get done for the V1 release because some of the work to enable it has been done. It depends on how things go during the next couple of months I guess.
> quote immission editor
I'm sorry, I'm not sure that I understand what you are asking for here. I think you're asking about annotation stuff such as text and dimensions? These definitely won't be finished in the V1 release, but I do want to add features in this area in future releases.
The final V1 release probably will be pretty similar to the beta release you've got right now. I'm not really trying to do all the features of every CAD program all in the first release, I'm more trying to get the basics and simple things to work easier and quicker than they normally do.
18.3 In reply to 18.2
Thx for answer, for immission editor i think a system like trasform attributes in attributes editor in maya for scale and other dimension.
18.4 In reply to 18.3
Ok, I understand now.
But no, I don't expect to have this type of transform history editing in the V1 release. I'm not really sure if MoI will ever have this particular type of history editing, the type of history that I'm going to be focused on (when it does come) is the relationship between objects, such as if you have an extrude and want to edit the curve that produced the extrude, and have the extrude update.
I think at some point there will be some properties available on an object that you can edit, such as width and height... But that will probably be pretty simple, not any kind of history or stack of transforms.
You can do a simple scale of an object right now by using Transform / Scale, though.
18.5 In reply to 18.4
If you implement parametric modeling like that I'll be your friend for life. I absolutely loved that about Autodesk Inventor, but that program is ridiculously clunky unless you have a blueprint to work from.
18.6 In reply to 18.5
At first the history is not going to be quite the same as full parametric modeling, it will be more focused on letting you edit the curves that were used as input to other commands such as extrude or loft.
But I have a lot of plans on improving the history over time, eventually it will become more possible to do more types of parametric style stuff. But the thing that will probably be missing altogheter is the concept of "constraint-based", which is another mechanism that those parametric solid modelers are based on. But that's also the part that makes them feel like you need to be working on a blueprint as well... It is powerful for a lot of things but as you mention tends to force you to do a lot of set up stuff, you don't get to freely draw so much.
You'll be able to mess around with the first history stuff in the next beta, which is looking like it will be on Monday.
18.7 In reply to 18.6
AHHHHH, so that's what "constraint based" means. I always wondered but never bothered to find out. Avoiding that sounds like a good idea. When you get into that you're going against some ridiculously serious competition. haha
18.8 In reply to 18.7
Yeah, it's the stuff where like you can like assign explicit dimensions to stuff like width, height, radius, etc.. and then have other parts of the model adapt or recalculate themselves according to the constraints. Then you might manipulate the constraints to provide for a family of parts and such.
Yup. Plus there are already a lot of things out there that handle this type of a thing quite well, I didn't really want to do something that was just the same as other things already out there, didn't seem to be much point in that.
Show messages: All  1  2-8
