I want this in MOI!!! Unbelivable tools!
 1-14  15-34  35-38
1774.35
That is brilliant. I am used to dealing with requests taking months, sometimes years to get fulfilled...and you've done it in a couple of days. Super impressed.
1774.36 In reply to 1774.33
Would it be too weird, if the Array/Curve worked in this manner as well?
- launch command Array/Curve
- push a Done button without selecting an object to array
- in this case, the point object was placed at the curve start point
- this new point became the object to array
It means the Array/Curve could be used as a Divide curve command in Rhino.
Petr
1774.37 In reply to 1774.36
Hi Petr, interesting idea... But yeah it maybe seems somewhat unintuitive for someone to think to try that (use the array function with no objects that is) to get equally spaced points.
It seems like a Divide command would maybe be a more expected place to find that kind of function.
One thing I had thought of was having options in a Divide command for either placing points, trimming the curve into multiple segments instead of just adding points, and maybe also producing a polyline from the curve as well.
So that seems like enough functions to make a separate divide function be worthwhile.
1774.38
Thank you ! I am realy happy that one of my wishes from the wishlist
has been fullfilled ... and in an awsomes extend !
thanks a lot !
Peter
Show messages:  1-14  15-34  35-38
