Shell Problem
All  1-7  8-11
1773.8
Will Moi get a patch function similar to rhino at some point?
If so, I was thinking it could be hidden in the Network command. It could help in cases like this chair. Or like attached screenshot of patch from Rhino.
1773.9 In reply to 1773.8
Hi Frederik, yes I hope to add that in at some point.
The one that was immediately available in the geometry library that I am using was just a little too "wild" and lumpy when I first attempted to use it. In the future when I get a chance to dig into it some more I think I should be able to get it to work though.
1773.10 In reply to 1773.9
That's good Michael.
BTW. The Sweep scaling rail and automatic profile placement are very clever!
-Fredrik
1773.11 In reply to 1773.10
>You have to join the 2 boundary curves first. They myst form a closed curve, and they should lie close to the >surface. Then it should be just to trim and use remove mode.
So did you draw your network surface to be shaped like the chair, then trim... Or did your trim shape the network suface (an original flat square)?
Show messages: All  1-7  8-11
