>You have to join the 2 boundary curves first. They myst form a closed curve, and they should lie close to the >surface. Then it should be just to trim and use remove mode.
So did you draw your network surface to be shaped like the chair, then trim... Or did your trim shape the network suface (an original flat square)?
