Wingtip help required.
All  1-8  9-11
1762.9 In reply to 1762.8
Hi Kevin,
Small tip, the surface will be as good as the underlying curves driving it. the better the curves are developed and the more accurate, the better the surface will be.
1762.10 In reply to 1762.9
Thanks Danny, that is really good advice and could well be part of the reason why I'm having problems getting a good surface and mesh from the wingtip. I think I'll rebuild those wingtip curves from scratch before applying the final surface.
~Kevin~
1762.11
This is the wing of a Bf109-F (WWII aircraft)
I thought I would post this problem here. I cannot create a wingtip that gives a smooth transition from the leading to trailing edge of the wing. Using the technique I've used (2 rail sweep and the scaling rail). It gives a bulged crimped wingtip.
As I suggested in another thread, perhaps if MoI had the ability of tweaking surfaces with point editing I could then tweak this wingtip to the correct shape as it is almost what I want.
Perhaps there is another way of approaching the modelling of the wing and wingtip so it gives the correct result, I am open to any suggestions help or advice ?
~Kevin~
Size: 58.2 KB, Downloaded: 67 times, Dimensions: 640x480px
Show messages: All  1-8  9-11
