Wingtip help required.
All  1-10  11
1762.11
This is the wing of a Bf109-F (WWII aircraft)
I thought I would post this problem here. I cannot create a wingtip that gives a smooth transition from the leading to trailing edge of the wing. Using the technique I've used (2 rail sweep and the scaling rail). It gives a bulged crimped wingtip.
As I suggested in another thread, perhaps if MoI had the ability of tweaking surfaces with point editing I could then tweak this wingtip to the correct shape as it is almost what I want.
Perhaps there is another way of approaching the modelling of the wing and wingtip so it gives the correct result, I am open to any suggestions help or advice ?
~Kevin~
Size: 58.2 KB, Downloaded: 67 times, Dimensions: 640x480px
Show messages: All  1-10  11
