Control Point
All  1-13  14-18
1746.14 In reply to 1746.13
Hi Petr...
>Did you download the file Nudge.zip or NudgeViewAxis.zip?
I downloaded the Nudge.zip
>Could you check a keyboard shortcuts?
>If you download and unzip the file Nudge.zip into the \commands subfolder under your MoI main program files folder,
>the items in the shortcut keys section should look like:
>PageUp Nudge zup
>PageDown Nudge zdown
Uppsss...not yet set up this.... Now working fine.
>You seem to have a script to rotate view there instead(?)
>PageUp script:moi.ui.mainWindow.viewpanel.getViewport('3D').rotate( 'up', 6.0 );
yes, correct.
>>when I use blend the result will be same if I use fillet
>Actually, those shapes are slightly different. The control point structure look similar for both fillet and blend in MoI;
>but if you would copy the curves to Rhino and turn control points on, you could see the difference.
I see now
>By the way, why do you exactly need that structure of control points?
I just follow a tutorial from Rhino3DTV on how to create a bottle. Check my previous post on this thread. I want to know how we can create the bottle in Moi3D.
Thanks for your tips... :)
1746.15 In reply to 1746.14
One other difference between Fillet and Blend, is that Fillet is done on 2 curves that are on one common plane with each other, while Blend works off the end of any 2 curves, they can be swooping around in 3d or whatever they don't have to be coplanar for blend.
1746.16 In reply to 1746.13
Hi Petr,
>>The control point structure look similar for both fillet and blend in MoI; but if you would copy the curves to Rhino and turn control points on, you could see the difference.
Are you not looking at a default fillet from MoI (Circular) compared to a default blend(G1).
Fillets in MoI can also be made to G1/G2/G3 so a need to compare similar settings (with fillet/blend) on such a planer construction.
1746.17 In reply to 1746.16
Hi Steve, I think the fillet with option G1/G2/G3 is not further fillet ;) From my point of view, it is just kind of smart blending for solid/polysurfaces. By the way, circular option also keeps a tangent (G1). -Petr
1746.18 In reply to 1746.17
Hi All....
Finally, below are the result :)
Size: 37.2 KB, Downloaded: 44 times, Dimensions: 470x641px
Size: 80.7 KB, Downloaded: 47 times, Dimensions: 720x676px
Show messages: All  1-13  14-18
