Control Point
All  1-12  13-18
1746.13 In reply to 1746.12
Hi Anis,
>>About nudge, I tried those script.
Did you download the file Nudge.zip or NudgeViewAxis.zip?
Could you check a keyboard shortcuts?
If you download and unzip the file Nudge.zip into the \commands subfolder under your MoI main program files folder, the items in the shortcut keys section should look like:
PageUp		Nudge zup
PageDown	Nudge zdown
You seem to have a script to rotate view there instead(?)
PageUp         script:moi.ui.mainWindow.viewpanel.getViewport('3D').rotate( 'up', 6.0 );
>>when I use blend the result will be same if I use fillet
Actually, those shapes are slightly different. The control point structure look similar for both fillet and blend in MoI; but if you would copy the curves to Rhino and turn control points on, you could see the difference.
Like Michael mentioned above:
quote:
MoI applies a kind of automatic "deformable" option when you turn on control points for an arc or circle curve.
By the way, why do you exactly need that structure of control points?
Petr
1746.14 In reply to 1746.13
Hi Petr...
I downloaded the Nudge.zip
>PageUp Nudge zup
Uppsss...not yet set up this.... Now working fine.
yes, correct.
I see now
I just follow a tutorial from Rhino3DTV on how to create a bottle. Check my previous post on this thread. I want to know how we can create the bottle in Moi3D.
Thanks for your tips... :)
1746.15 In reply to 1746.14
One other difference between Fillet and Blend, is that Fillet is done on 2 curves that are on one common plane with each other, while Blend works off the end of any 2 curves, they can be swooping around in 3d or whatever they don't have to be coplanar for blend.
1746.16 In reply to 1746.13
Hi Petr,
Are you not looking at a default fillet from MoI (Circular) compared to a default blend(G1).
Fillets in MoI can also be made to G1/G2/G3 so a need to compare similar settings (with fillet/blend) on such a planer construction.
1746.17 In reply to 1746.16
Hi Steve, I think the fillet with option G1/G2/G3 is not further fillet ;) From my point of view, it is just kind of smart blending for solid/polysurfaces. By the way, circular option also keeps a tangent (G1). -Petr
1746.18 In reply to 1746.17
Hi All....
Finally, below are the result :)
Size: 37.2 KB, Downloaded: 44 times, Dimensions: 470x641px
Size: 80.7 KB, Downloaded: 47 times, Dimensions: 720x676px
Show messages: All  1-12  13-18
