V2 beta Jul-3-2008 available now
 1-11  12-31  32-51  52-58
1742.52 In reply to 1742.51
Hey Brian,
It's actually good to be curious about this stuff. Thats what makes you good at it.
Let me partake.
When you select a checkbox in MoI's options dialog, How does it know you selected that option the next time you open Moi?
The answer is an "ini file". Alot of apps use them. Usually you can find it in the root folder of the application. (It's just a simple text document that the application can read and write to. To store those "Settings".
Do you know what Windows explorer is?
Hit the windows key and E at the same time. then navigate to the MoI folder. (if you dont know what that means I can explain further)
In that folder is where you will find the MoI.ini file. Open it with notepad.
Just look around at first, dont change anything.
In there you will see a bunch of lines that seem odd but you can soon recognize them. As with the checkbox example I started with, there could be a line that say's "checkbox1.state=y" What that could mean is that Michael named one of his checkboxes "checkbox1" and then it has things that can be set like the "state" with a value of Y(es) or N(o)--Checked or unchecked--!. Sometimes 0 means yes and 1 means no. Get it?
What they are talking about is changing the behavior of things in Moi without actually cluttering up the UI with more checkboxes and things. (Soon there would be 50 checkboxes, one for Burr, one for Brian, etc.....).
Ask again if you want more info, I can talk to you about what it is, but for specifics on how to use it, there are others that could answer better.
Burr
1742.53 In reply to 1742.51
> You are saying that that stuff I can not actually see/find,
> or access anyway, in the MoI App folder?
It's normally in this folder (for Windows XP):
C:\Documents and Settings\ [your login name] \Application Data\Moi\moi.ini
Windows will by default hide that "Application Data" folder, but if you turn on some setting in Windows explorer to show hidden files then it should show up, or also you can just type in that folder name and it will go there even if it was not displayed in the regular Explorer view.
1742.54 In reply to 1742.53
There I go with incorrect advice again! maybe I should just give up. :)
Burr
1742.55 In reply to 1742.53
Found it, thanks.
Brian
1742.56 In reply to 1742.54
Hi Burr, actually all the stuff you mentioned was spot-on except for the location of the file.
Definitely it makes it easier for me to add in special settings to that file only rather than cluttering up the UI for every single thing.
I wish that I could put the file in the location where you expected it (in MoI's main folder in \Program Files\), except Windows does not allow users with limited access accounts (like not set up as a machine administrator) to write any data into that folder. So to support limited users in XP, (and also just regular users in Vista now), I write that file by default into that other location which a limited rights user is allowed to write into.
You can actually move the moi.ini file into the main program folder where MoI.exe is if you want to - MoI will check for it there first and use it from there if it finds it. That's also what you need to do if you want to bring MoI along with you on a USB stick and also bring along your settings.
1742.57 In reply to 1742.56
Yeah I just wasnt thinking. I keep mine in the app root "Beacause" I use the usb stick function to go to my brothers house with MoI!
"REALLY" love the usb option you give us!
Burr
1742.58
Michael,
I really, really like the scale/rotate manipulator. Using the menu for that got quite tiring.
Great work!
I'll give the surface snapping a try when I have more time to play with it.
Show messages:  1-11  12-31  32-51  52-58
