Meshing Question
All  1-5  6-11
1723.6 In reply to 1723.5
Hi isaac, a few general settings to try are:
Try angle at 20, 25, 30, and also try a really big angle like 90.
Then try "Divide larger than" at around 2, 1, or 0.5 - the value you put here is a distance for what size you want your final polygons to be so the distance that you use here should be kind of relative to the size of your object, like don't put in a value that is 1/10000th the size of your object or you will get quite a lot of polygons.
You may need to try a few combinations of those different angles and lengths before you get one that really eliminates all terminating edges, it may not always be possible to get rid of all of them. But for example in your object you posted an angle of 25 and "Divide larger than" of 2 did seem to get rid of them all.
I would like to add a few more meshing options in the future to try and give some additional control over it.
1723.7
Hello Michael,
I'm just have four questions about the meshing tool too.
1) The first time you export an object in a polygon format (.lwo .obj), the meshing tool is using a default settings value. (12° angle, weld vertices on, etc.)
With this default value it might already take quite some time to have a feedback, and most of the time I will change this value and this 'waiting time' is somehow lost.
So I was wondering if it's technically possible to show the actual settings used in the viewport in fact, as I suppose we already see a mesh version of the
nurbs model. That would give a first realtime preview of the mesh.
Of course keeping any new settings for the next export as it's working now it's just fine.
2) Running the meshing tool as a command without having to export my model would be a nice feature too (but maybe it's already possible ?) it helps me sometimes to check my model during my modeling process, ... maybe it's because I'm coming from polygon modeling school too.
3) Is the 'add detail to inflections' from the view option working a little bit like the 'avoid smaller than' from the meshing command ? (just by curiosity)
4) If question 1) is impossible to archive, having somehow a way to export the poly model as it is in the viewport, so without any extra meshing computing, would really
boost my workflow. This would help to really quickly export my model, even if it's a draft one, and allow me to make some quick preview in my rendering package, testing some materials etc.
EDITED: 29 Jun 2008 by PAQ
1723.8 In reply to 1723.7
Hi PaQ,
re #1:
The plan I have for solving this is to make it possible to interrupt the mesher if you enter new values when it is currently calculating. Most regular commands do work this way already, like if you are doing a fillet and it is taking a long time to finish, if you enter a new fillet radius it will automatically cancel the current fillet calculation and start a new one with the new radius.
Doing the same kind of thing for the meshing dialog should make this work a lot smoother, the meshing dialog is just different enough from a regular command that I have not had a chance to make that happen yet.
> a mesh version of the nurbs model. That would give a first realtime
The problem there is that the viewport/display mesh is actually created with a different meshing process than the export meshing. The display mesh mechanism is very oriented towards calculating a result very quickly and sort of errs on the side of creating denser meshes. The export mesher does a different job and does a lot heavier and time consuming calculations to make more efficient and evenly spaced meshes, it's oriented more towards mesh structural quality and not towards execution time like the display mesher is.
So it just won't work very well to show the display mesh as a temporary result, it is just not the same mesh that is created for export at all.
> model would be a nice feature too (but maybe it's already possible ?) <..>
I do this frequently myself to test the mesher - to get this set up, create a keyboard shortcut with this as the command on it:
SaveAs c:\test.obj
Or use Export instead of SaveAs if you want to only do selected objects instead of the whole scene. Now when you hit that key, the mesher will fire up and after you have looked at the result press Esc or Cancel to bail out without writing the "test.obj" file.
> (just by curiosity)
It's a bit different than that - it's an option to try and actually increase the density of a mesh, while the "Avoid smaller than" is trying to decrease it.
The way it works is that it will force additional meshing subdivisions to happen in areas where there is an "inflection point". That's an area where the surface is changing curvature from one side to another. Like on a curve that is "S" shaped, the inflection point is the middle of the S where the curvature swaps from one side to the opposite side. It can look nicer to have refinement happen in these areas, and part of the reason why the display mesher is faster than the export mesher is that it takes some shortcuts and can more easily miss refining some areas than the export mesher, this piece of the display mesher tends to help compensate for that and give some detail in little tight areas that can be kind of noticeably rough in shading when they are not subdivided enough.
re: #4 - I would like to add some mechanism for exporting the display mesh at some point, that is actually on the wishlist already. But it is not a very beautiful mesh structure, it is triangles only, tends to be quite overly dense than necessary, and currently has T-junctures on shared edges instead of completely matching vertices along edges.
1723.9 In reply to 1723.8
Ok thanks for the explanations.
Be able to interrupt the meshing is indeed a more elegant method that what I was thinking.
and thanks for the shortcut, so simple :o)
For the #4, yes I can imagine it would be a really draft model ... maybe an 'hidden' command is enough I'm
not sure many people would be interested by exporting an ugly models. As I said it's just
to have a quickly preview of 'complex' object in my renderengine ... where I do care more about proportion,
volumes etc that perfect smoothing shape ...
But again if I can abort the meshing command and put some high angle option, it would be cool enough.
(or maybe be able to add arguments to the command, like SaveAs c:\test.obj -Output triangles -Angle 50 -Avoid smaller 4)
Cheers.
1723.10 In reply to 1723.9
Hi PaQ,
You can actually do this part now by using a script, for that put in this as the command name for the keyboard shortcut instead:
script:moi.geometryDatabase.saveAs( 'c:\\test.obj', 'Angle=45;Output=quads' );
You can put in different parameters with this method. Each parameter should be separated from the others by one semicolon.
// Different possible options:
// NoUI=true
// Angle=12.0
// Output=ngons | quads | triangles
// MaxLength=0.0
// MaxLengthApplyTo=curved | planes | all
// MinLength=0.0
// AspectRatio=0.0
// Weld=true
// Display=shadedwithedges | shadednoedges | wireframe
// ExpandedDialog=false
Except there is a glitch in v1 where when you cancel the dialog when running outside of a command like this, the cancel will actually get queued up and so every other time you run it in a row will get canceled, so the shortcut will only work on every other keypress. I have just fixed this up for v2 though.
1723.11
that's fine for now Michael, thanks a lot I will give a try !
Show messages: All  1-5  6-11
