Insert new text
All  1-8  9-15
1720.9 In reply to 1720.8
Hi Luca, Hi Steve, I see what happens.
When you get to the first stage of the Text command, where it asks you for "Pick base point", if you right-click there instead of picking a point it will cancel the command and mistakenly set the default font name to be blank. (this is kind of easy to do if you are using right-click to repeat the command a bunch of times).
Then if you run the command again after having done that, you'll see that the Font: dropdown (where you pick the font name like Arial, Times New Roman, etc...) is actually blank instead of having a font name filled in there.
If you try to create text with the font name blank like that it will fail.
So a quick fix for the moment is if you see the command fail, fill in the Font: dropdown name so it has a proper font name in it and then it should work again.
I think I should be able to fix this pretty easily with just an update to the Text command script file, I will take a look at that just shortly.
EDITED: 26 Jun 2008 by MICHAEL GIBSON
1720.10 In reply to 1720.1
Hi Luca, I've attached a fix here.
To install the fix, unzip the attached Text_fix.zip file to get Text.htm, then copy that file over top of the old version inside of the \commands subfolder inside of MoI's main installation folder (like c:\Program Files\MoI 1.0\commands).
With this update in place the Text command should not get "stuck" anymore. Please let me know if you still run into the problem after installing the fix and thank you for reporting the bug!
1720.11 In reply to 1720.10
Hi Michael thanks for the fix.
It's working fine here.
I haven't notice that the font dropdown was blank....
Ciao
Luca
1720.12 In reply to 1720.11
I have finally finish the modelling of the keyboard, thanks to Michael fix.
Here is the result:
And a quick render in Fryrender:
Thanks for watching!
Luca
1720.13 In reply to 1720.12
It turned out great Luca!
1720.14 In reply to 1720.12
Added same views with less noise DAY & NIGHT. Now I will start modelling my first car!
Ciao
Luca
Neat result!
Show messages: All  1-8  9-15
