Weird shell bug
All  1-6  7-13
172.7 In reply to 172.6
An another thing :)
I have reload your object
You have made a too large Shell measure!
Try with 0.2 that work!
It's because some angles are too acute!
It was visible on the first image on your section, lines are acrossed :)
But I don't take care of :)
EDITED: 18 Oct 2006 by PILOU
172.8
Be careful when using "shell". Moi doesn't warn you, but it often will create invalid objects (OK for illustrations, but NOT OK for manufacturing or serious ind design). Invalid objects will make it impossible to do some volumetric operations later. Usually the problem occurs when a fillet is a 3-sided surface. It has much less problems if you take care that all sub-surfaces are 4-sided...
172.9
Thnx a mil for the help
THor
It's for that than a message of exceedence angle will be super cool!
Now prog goes in infinit loop...or make some bugs images :)
172.11 In reply to 172.8
Hi jbshorty,
If you have any examples of this, please post them, I might be able to fix this up.
172.12 In reply to 172.11
Hi Michael.
Here is an example file. Both are solid polysurfaces, but the one with 3-sided filleted corners is an invalid object.
jonah
172.13 In reply to 172.12
Thanks Jonah - I see the problem, the offset of the 3-sided fillet is not totally clean, the points that are supposed to be all collapsed together at the pole are slightly separated. This is messing up stuff later on.
I think I should be able to fix this up, but I won't be able to give it a try until after the new meshing stuff is done.
Show messages: All  1-6  7-13
