Weird shell bug
All  1-10  11-13
172.11 In reply to 172.8
Hi jbshorty,
> Usually the problem occurs when a fillet is a 3-sided surface.
If you have any examples of this, please post them, I might be able to fix this up.
172.12 In reply to 172.11
Hi Michael.
Here is an example file. Both are solid polysurfaces, but the one with 3-sided filleted corners is an invalid object.
jonah
172.13 In reply to 172.12
Thanks Jonah - I see the problem, the offset of the 3-sided fillet is not totally clean, the points that are supposed to be all collapsed together at the pole are slightly separated. This is messing up stuff later on.
I think I should be able to fix this up, but I won't be able to give it a try until after the new meshing stuff is done.
Show messages: All  1-10  11-13
