bevel !
All  1-7  8-11
1717.8 In reply to 1717.7
This last one is more confortable :)
1717.9 In reply to 1717.7
verry good , manz !!!!
Exactly what I wanted to do , can you explain me the progression.
I had tested, but I do not arrive at the same result!
Vincent
1717.10 In reply to 1717.9
Hello,
You just now need to make a sweep using profiles from the part you have made(with the rads), using rails from the seat part.
Select the back and join the edges for the profile, then select the seat, and copy paste the edges for the rails. Then use sweep.
Just be careful with the rails, you will need to trim/rotate the back rail or you will get a bad blend (the surface will have creases)
Hope that helps, if not, I will post the model and explain more.
EDITED: 3 Aug 2009 by MANZ
1717.11 In reply to 1717.10
Thanks manz
It's verry good solution ..
verry Thanks
Vincent
Size: 373.2 KB, Downloaded: 31 times, Dimensions: 2646x1380px
Show messages: All  1-7  8-11
