bevel !
All  1-2  3-11
1717.3 In reply to 1717.2
Hi osx59 - here is a bit more of a description of the alternate method, this is pretty rough but might give you an idea on a different approach.
To start with I drew several curves like this:
Then I used Construct / Loft to make a surface out of them:
Then extrude that surface to get your volume shape:
Get some 2D curves on the bottom to act as cutters:
Do boolean difference to cut those out of the shape:
Then this has a much fewer number of curves and corners that have to be built, this kind of thing is more easily filleted:
That kind of an approach has a lot fewer pieces involved, that can often times make filleting work better.
Extrude or Shell+trim ?
1717.5 In reply to 1717.4
Hi Pilou - If you look at the original model, it has a kind of "steep"-ness to it, that is the type of thing generated by extrude.
Shell will produce something like this:
That kind of has movement in many different directions, the new surface is along the surface normal of the original shape and not just in one single direction.
Extrude moves only in one single direction, that's more like the original shape.
1717.6 In reply to 1717.5
yes, but the original form is not" natural" and difficult to built in reality and dangerous to use ;)
1717.7
Thought I would have a quick play.
I made profiles/rails from the shape given,.. added fillets to the profiles, then swept the surfaces.
EDITED: 3 Aug 2009 by MANZ
1717.8 In reply to 1717.7
This last one is more confortable :)
1717.9 In reply to 1717.7
verry good , manz !!!!
Exactly what I wanted to do , can you explain me the progression.
I had tested, but I do not arrive at the same result!
Vincent
1717.10 In reply to 1717.9
Hello,
You just now need to make a sweep using profiles from the part you have made(with the rads), using rails from the seat part.
Select the back and join the edges for the profile, then select the seat, and copy paste the edges for the rails. Then use sweep.
Just be careful with the rails, you will need to trim/rotate the back rail or you will get a bad blend (the surface will have creases)
Hope that helps, if not, I will post the model and explain more.
1717.11 In reply to 1717.10
Thanks manz
It's verry good solution ..
verry Thanks
Vincent
Size: 373.2 KB, Downloaded: 31 times, Dimensions: 2646x1380px
Show messages: All  1-2  3-11
