Bug Bug
1705.1
Draw a line through the origin (y-5 to Y5 or something) and then use the Cont Arc from the origin (0,0) and the arc is not drawn. The arc will be drawn at any given position, except for the ends and the origin. Ends are not providing the 'Cont' function with a valid result, but the Origin has a solution.
Lemo
1705.2 In reply to 1705.1
Yes, vicious bug :)
So take the Arc by 3 points if you are blocked at 0,0,0 ;)
EDITED: 21 Jun 2008 by PILOU
1705.3 In reply to 1705.1
Uncheck 'origin' in object snap, it looks like it's getting confused between end/origin or mid/origin, Michael ?
1705.4 In reply to 1705.3
Hi Lemo, Hi Danny - yup this is a bug where that command is getting confused when seeing the Origin snap. It looks like I should be able to fix it up for v2 right now.
1705.5
Yeahhhhh! Squashed!!!
That's how I like Bugs 8))))
Lemo
1705.6 In reply to 1705.5
Hi Lemo, yes just to verify this is now fixed for the first v2 beta, which is getting awfully close...
Thanks for reporting the bug!
