Work & Play ~ WIP
All  1-2  3-8
1703.3 In reply to 1703.1
Hi DannyT
That was an interesting job.
Nice rendering, and nice model.
Is your regular app. SolidWorks?
Also, do you know the price of tooling for that thing?
I'm interested because i have a product idea which i think requires injection moulding.
My thing is a bit more complicated and a bit larger than yours, but i have considered draft angles and stuff so it should be sensible.
-Fredrik
1703.4 In reply to 1703.1
Hi Danny, that is an awesome result!
What would you say were some of the biggest things that you missed from your main solid modeling app while working in MoI? I can certainly guess some history tree editing like changing fillet radii later on, but what about stuff other than that?
1703.5
Thanks Guys,
Yes MoI is refreshing to model with Moe, it actually has a sort of addictive affect, I think Michael has some subliminal mind altering code in there somewhere ;)
Hi Fredrik,
>>is your regular app. SolidWorks?
No, Siemens NX4
Depends on where you get it made, Australia, US ,Europe = quality (most of the time), China for a low budget, but you must find a mouldmaker that appreciates quality, but as the quality goes up so does the price. It also depends on how many parts you intend to produce, you could get a quality mould that would produce parts for 3-5 years before any maintenance or you could get a mould that would last for 10-15 years without touching it, thats where the $$$ come into it.
If you have any more questions on this Fredrik you can PM me.
It would probably vary from job to job, but for this particular model the main bother was when joining a closed network of surfaces, not knowing which was the offending surface that stopped the model from becoming a solid, so had to anylise the model in another app, did a sheet boundry analysis where it tells you how many boundries you have, 1= solid, more than that you have holes, then it highlights where surface boundries don't match or join, fortunatly for me it was only one surface which I rebuilt easily in MoI and everything was a solid again.
Next, I missed variable filleting, but got around that with network and then there is draft angles, you have to think a little more, for example, it would be nice to place all the holes in your model then apply the draft angle you need later, but it didn't take much longer to draw circle, then line at angle, then revolve and array or copy into positions then a boolean operation.
But If you had alot of ribs in your model it would be a painful process to draw lines at 1 or 2 deg and do boolean difference.
Other than that it was a joy to use on a paying job.
EDITED: 21 Jun 2008 by DANTAS
1703.6 In reply to 1703.5
Thanks Danny
-good help for me those tips.
I'll send you pictures of my part.
-Fredrik
1703.7
Just an update,
The prototype has just been received, the yellow goop is the stuff the dental technician uses with this product to take dental impressions.
We are now in discussion about the plastic injection mould to mass produce the product.
I would of liked more pictures but this is all the customer sent me.
1703.8 In reply to 1703.7
It is so cool to see shots like this running from the design on the computer to the final product, thanks for sharing it!
Show messages: All  1-2  3-8
