fillet trouble
All  1-15  16-19
1700.16
"Mesh Angle: increase for better performance (try 15 or 20), you can also disable the "Add detail to inflections".
As manz mentioned, turning off the "Add details to inflections" really helps with any display slow down - saved my bacon just last week (on a relatively simple model too.)
-Will
1700.17
A similar issue. However, I don't understand why fillet is having issues with the R, especially since I have managed to fillet the other letters just fine. The odd thing is that I have managed to get fillet to react once, but never after using the same radius.
I have attached the scene.
1700.18 In reply to 1700.17
hi maybe a little trick
I have scaled x 10 the entiere model then made the fillet 0.2
I have not made the fillet base on this picture, but the fillet works also for the base!
(file 3Dm linked with base ;) (not unscaled / 10 !!! )
So you can "unscaled" / 10 at the end ;)
So I believe you work at a too little size scale of project unity ;)
EDITED: 16 Jul 2008 by PILOU
Size: 29.3 KB, Downloaded: 32 times, Dimensions: 540x334px
1700.19 In reply to 1700.18
thank you very much. That solved the issue :)
Now i can finally finish the model :D
Show messages: All  1-15  16-19
