Does scale matter?
All  1-10  11
1688.11 In reply to 1688.10
Hi Danny,
> Ok, So if I model scaled down, say 1:10 of the size I want,
> then after finishing that model could I scale it to actual size for export ?
Yup, that would work fine.
If you have your units set (under Options / General / Unit system) to Centimeters, then you can scale your model before exporting by just switching that to Millimeters - that will do the scaling for you unless you have turned "Scale on unit system change" off under Unit options.
You can also scale everything to a particular scale factor by using Transform/Scale. To do that, select all objects, run Transform/Scale, type in "0" <enter> to pick the 0,0,0 origin point as the scale origin, then type in your scale factor for example 0.1 to scale by 1/10.
Show messages: All  1-10  11
