duplicated mesh
1678.1
I have downloaded MOI to test mesh export but when I export to OBJ and then import into Rhino I get all objects 2 times.
When I select one object mesh Rhino will allow me to select 2 objects since there are 2 there.
Is this a bug?
My problem?
Sergio
1678.2 In reply to 1678.1
did you Paste those objects from a Rhino seesion into MoI? any chance you pasted twice by mistake?
jonah
1678.3 In reply to 1678.1
Hi Sergio, I haven't heard of this problem before... Can you make sure you don't actually have 2 copies of the object on top of each other inside of MoI?
It is hard to give you a definite answer without seeing the file though, can you please post the .3dm model file (or send it to me at moi@moi3d.com) so I can take a look and see if it is a bug or if it is duplicated objects in the file?
1678.4
Hello to all
Thanks for the reply, I have copyes again the file and maybe that was the problem , maybe I copyed twice.
The mesh is great now.
moi seems very interesting, I will investigate further.
Sergio
