Trim Question
All  1  2-11
1677.2 In reply to 1677.1
Hi Danny,
>>so does this mean that the underlying surface is still there
Yes.
>>if it is possible to untrim a surface
currently in MoI, no.
Eventually, IMHO, Michael will need to add more tools for surface work, as currently it can be a pain.
- manz
1677.3 In reply to 1677.1
Hi Danny,
Yes, the surface is still there but if the trim curve is within the boundry you can select and untrim it but if
it happens to run to the outer edges you are stuffed !!
>> For example I read in another post someone wanted to change a chamfer size after opening an already
>> saved model, we could then separate these surfaces that have the chamfer applied, then untrim to original
form, join, then apply the new chamfer size.
Yeah, a higher level of trim/untrim would be nice in MoI.....I think perhaps this kind of funtionality will come when
we start to see surface matching incorporated ???
Rgds,
--Paul--
1677.4 In reply to 1677.2
No, you can...
quote:
Untrim: You can untrim a surface by selecting all the edges of one of its boundaries and using Delete. This erases the trim and gets you back to the underlying surface.
1677.5 In reply to 1677.4
Hi tyglik
I stand corrected.
I thought I had seen a post stating it was not possible. Where did you find that quote?
I have just looked through the command ref (that came with MoI) and I cannot find that quote. I did find a ref under "delete", which is why I missed it.
- manz
1677.6 In reply to 1677.5
Hi Steve, it was a part of Sep-4-2006 beta announcement.. :) -Petr
1677.7 In reply to 1677.4
ahhhhh !!! I knew it was possible for internal trims using the same method but......
Thx tyglik
Rgds,
--Paul--
1677.8 In reply to 1677.1
Hi Danny - I think you already have the answer to your original question, that you can use Delete to "untrim" a surface (and recover the underlying surface) if you have all the edge curves for a trim boundary selected.
Sometimes for this kind of "low level" object repair procedure you may also want to copy several of the edge curves to the clipboard first before doing the untrim, so that you can paste back in some that you want to keep the same to use for the next re-trim.
There is a tutorial that I did back a while ago here: http://moi3d.com/forum/index.php?webtag=MOI&msg=446.17
which covers this kind of low level object repair techniques in some detail. That one was to repair a boolean that was done in a wrong location but not noticed until later on.
The basic procedure is to use Separate to break solids into individual surfaces, untrim surfaces, re-trim them, and use Join to glue things back together.
One thing to remember is to untrim you must select all the edges that make up the trim boundary - that means a full trimming loop not just one edge that is a portion of the trim loop.
1677.9 In reply to 1677.3
Hi Paul,
I think you already figured this out, but to make sure - when a trim runs to the outer edges you can still remove it, but you must select all the edges for the entire loop, not just one.
So for example if you have this situation, don't select just this one edge:
Instead you must select all these edges for untrim:
It is on my list though to improve untrimming to make the first type of selection work though, I'm not sure yet when that will happen.
Also a shortcut can often be used to select all edges - first select one and then do Select/Select All (or Ctrl+A) - When select all sees that there is a partial edge selection it will go through and select all the other edges of a surface or solid.
One last note - when you have a closed surface like a cylinder for example, then the "seam" edge of the cylinder can also be part of the full trimming boundary loop so you sometimes have to select it as well to get the whole loop.
1677.10 In reply to 1677.9
Thx Michael,
Yup figured it out now thx to tyglik, that would have saved me a few copy paste's hahaha
Hidden power we love it !
Rgds,
--Paul--
1677.11
Wow! that was easy, thanks guys, could of saved myself a couple of hours searching the forum before committing to post this question ;-(
>>There is a tutorial that I did back a while ago here:http://moi3d.com/forum/index.php?webtag=MOI&msg=446.17
yeh, I did see this tut Michael but as the old saying goes 'a picture says..............'
Thanks Again
Show messages: All  1  2-11
