Seems like a bug to me....
All  1-4  5-8
1673.5
The reason I did this, was that I needed to make an extruded curve, thinner... The solid was already rotated.So I copied it downwards half it's width and I tried to subtract.
Anyway, of course there is an easy workaround
Here's the 3dm file
***Modeling Of Ideas***
1673.6 In reply to 1673.5
I think you have a point where the two items are too close to symetry?
If you do the boolean in the reverse order it works ok for me anyway.
Brian
1673.7 In reply to 1673.5
Hi JTB, thanks for posting the example. Yeah that is actually does not leave too skinny of bits, so that stuff I posted earlier doesn't really apply here.
It seems to be getting confused with the coincident surfaces in this case, if you thicken the cutting one by scale1d so that it doesn't have side faces that are coincident with the other one, then it will work.
I'll put it on my list to investigate to see if I can improve it.
1673.8
OK,thanks!
Show messages: All  1-4  5-8
