Make Surface
 1-8  9-26
1665.9 In reply to 1665.7
Hi Steve,
>> But how did you construct those surfaces?
Curve network for both surfaces - read my reply above to Michael.
>> There are some problems, but for the expected user, then I think most should be OK
I would interested to hear about the ones you come up against the most, hopefully I can
avoid that situation ;-)
>> Interesting. Is there limits/avoidance on that?
>> MoI does not include checking for that (deviation etc), but I am interested on what
>> you attempt and expect from such software
Given the shape in my example there is only so much you can do between the section
curves anyway, so long at the shape looks smooth that is all im looking for. Actually, that
is not entirely accurate as there are situations whereby it must meet a certain volume too
but we won't go into that here....
>> I could say,.. use solidworks,... or solidedge,.. I know and use them, but that is work
>> for me. MoI can be a pain sometimes due to some limitation, but come on,... for the
>> price,... I purchased license not based on how it is now, but more on how Michael
>> will continue.
Okay....your'e getting your own back now ? was that intended or me ?
Many thx in advance,
Rgds,
--Paul--
1665.10 In reply to 1665.8
Hi Steve,
The error you talk about is more to do with continuity right ??, I did actually match & improve on G0 in Rhino but I wasn't
happy with the result due to the surface isocurves going to a single point, thats where I lost the control.
Building the surface as one is usually the best option in terms of overall smoothness and your first comment the other day
was 'spot on' as splitting the profile helped make a good surface as shown in your analysis. I say good because if you turn
the surface and look end on there is a crease when the surface again meets at a point.
Are there any other ways to build such a shape or how might it be possible to further smooth your example ?
Many thanks in advance,
Rgds,
--Paul--
1665.11 In reply to 1665.10
Hi Paul,
>>but I wasn't happy with the result due to the surface isocurves going to a single point
Split the base control curve into 4(curve split at tangent/intersection) then network in MoI:-
This is the surface produced in MoI but viewed in Rhino:-
- manz
EDITED: 3 Aug 2009 by MANZ
1665.12 In reply to 1665.10
Hi Paul,
>>I say good because if you turn the surface and look end on there is a crease when the surface again meets at a point.
What did you use to check the surface? If you are just looking at the model in MoI then you may just be seeing an error in the created mesh not the actual surface.
- manz
1665.13 In reply to 1665.12
This is my little example.
I took the MoI file as an .obj file directly into Carrara.
Most surprised how many of the various choices for networking would not or were not good!
EDITED: 31 Dec 2008 by BWTR
1665.14 In reply to 1665.12
Hi Steve,
Before I did as you suggested in your previous post I took the model into Rhino and shaded it, if you look you
can see a bad crease on the end.
This method of further splitting the curves is an excellent idea !! Thanks
There is one small area which still doesn't look quite right and im not sure how that could be resolved. Looking
at the profile of the surface you can see that the iso curves don't quite make it to the end of line and it is this gap
to the arc where the deviation is taking place.....this would also be a pain to machine in the area.
If you have any further ideas I would like to hear them. :-)
TIA
Rgds,
--Paul--
Size: 61.3 KB, Downloaded: 47 times, Dimensions: 706x434px
1665.15 In reply to 1665.13
Hello Brian,
It's hard to say but I don't think your surface follows the curves both directions ?
Rgds,
--Paul--
1665.16 In reply to 1665.14
Hi Paul,
Move the splitting of the base control line to the ends,.. it does less pulling on the end areas.:-
If there is still a problem, then I would suggest a surface "rebuild" in Rhino.
1665.17 In reply to 1665.16
Hi Steve,
Perfect! - I have learned a lot using the network command in MoI and the various splitting of curves to make major
& subtle differences - Thanks for your time on this one.
I will be cutting this model in the morning :-)
Rgds,
--Paul--
1665.18 In reply to 1665.17
karter
Is this ok?
(It's the same file with a different render setting._
Brian
ps. The MoI screen shot shows the only way I could get a nice smooth network result. Doing a left and right version and joining them.
(Sorry if I am missing the point somewhere but could not my end result be as clean/smooth as is required.?)
1665.19 In reply to 1665.18
Thanks for the reply. If you look at the previous posts and Manz method of splitting the curves in a particular manner to create a network surface that works the best...try it and see ?
Building half or even quarter surfaces with limited geometry like I have requested will definitely cause problems with continuity after being mirrored into a full shape...maybe V2/V3 will have some matching capabilities that would help this cause.....
Thx again.
Rgds,
--Paul--
1665.20
You must be cautious to use Network for this type of surface. When input curves are G1, the resulting surface might seem OK and will be valid. BUT there is usually a problem with the surface normal at the corners. Try to Offset the surface and see what happens... If you're not planning any downstream operations that will confilct with this (shelling, fillets, etc) then it probably won't be a big deal...
jonah
1665.21 In reply to 1665.20
jonah
I can't get over how difficult this particular shape is.
I tried making it in several of my other subD and Nurbs apps also and MoI is WAY ahead!(Well I could not do it in any of them!)
What is it in this shape especially that creates problems I wonder?
Anyway, for use in my normal 3D rendering apps I at least got a fine result eventually---with thickness!
(What a time waster!)
Brian
1665.22 In reply to 1665.21
You should be able to create the surface in other applications even poly apps, for example, I created the surface in Hexagon from the line data (the other poly programs would not import the line data, so did not attempt).
In MoI/Rhino you would build using "network", in poly programs you would use (as in Hexagon) "Gordon surface". I am not saying the resulting surface would be accurate enough for machining, but it can be easily modeled from the curves given.
- manz
1665.23 In reply to 1665.22
Manz
1.Are you saying you created the same lines in Hexagon and enabled Gordon surface to them.
2.and/or you imported the line data to Hexagon in "?format" (from?)and enabled Gordon surface to the lines
Is it a Brian day? I can not do either!
Brian
1665.24 In reply to 1665.23
I converted the line data into DXF then imported into hexagon, I did have to weld some lines/curves to create the correct lat/long sections needed.
- manz
1665.25 In reply to 1665.24
Thanks.
What a complex world!
Brian
1665.26 In reply to 1665.25
Unless you purchase MoI of course :-))
Rgds,
--Paul--
Show messages:  1-8  9-26
