Make Surface
 1-18  19-26
1665.19 In reply to 1665.18
Thanks for the reply. If you look at the previous posts and Manz method of splitting the curves in a particular manner to create a network surface that works the best...try it and see ?
Building half or even quarter surfaces with limited geometry like I have requested will definitely cause problems with continuity after being mirrored into a full shape...maybe V2/V3 will have some matching capabilities that would help this cause.....
Thx again.
Rgds,
--Paul--
1665.20
You must be cautious to use Network for this type of surface. When input curves are G1, the resulting surface might seem OK and will be valid. BUT there is usually a problem with the surface normal at the corners. Try to Offset the surface and see what happens... If you're not planning any downstream operations that will confilct with this (shelling, fillets, etc) then it probably won't be a big deal...
jonah
1665.21 In reply to 1665.20
jonah
I can't get over how difficult this particular shape is.
I tried making it in several of my other subD and Nurbs apps also and MoI is WAY ahead!(Well I could not do it in any of them!)
What is it in this shape especially that creates problems I wonder?
Anyway, for use in my normal 3D rendering apps I at least got a fine result eventually---with thickness!
(What a time waster!)
Brian
EDITED: 31 Dec 2008 by BWTR
1665.22 In reply to 1665.21
You should be able to create the surface in other applications even poly apps, for example, I created the surface in Hexagon from the line data (the other poly programs would not import the line data, so did not attempt).
In MoI/Rhino you would build using "network", in poly programs you would use (as in Hexagon) "Gordon surface". I am not saying the resulting surface would be accurate enough for machining, but it can be easily modeled from the curves given.
- manz
1665.23 In reply to 1665.22
Manz
1.Are you saying you created the same lines in Hexagon and enabled Gordon surface to them.
2.and/or you imported the line data to Hexagon in "?format" (from?)and enabled Gordon surface to the lines
Is it a Brian day? I can not do either!
Brian
1665.24 In reply to 1665.23
I converted the line data into DXF then imported into hexagon, I did have to weld some lines/curves to create the correct lat/long sections needed.
- manz
1665.25 In reply to 1665.24
Thanks.
What a complex world!
Brian
1665.26 In reply to 1665.25
Unless you purchase MoI of course :-))
Rgds,
--Paul--
Show messages:  1-18  19-26
