Repair Surface
1648.1
I have a surface (made a few years ago) that I have imported into MoI by IGES.
The surface is open at the seam and therefore I wanted to align the cv's to close up the gap. My problem is I can only window points so far, I mean before the window box selects point im not interested in. If I zoom into the area and try to use select by box it moves the surface!!. I dont appear to be able to lock the surface after I have turned on points so that a further selection can be made.
If we had wireframe view or select next U (heheh) that would be the ticket unless one of you guys knows of a way pls ?
Rgds,
--Paul
Size: 167 KB, Downloaded: 58 times, Dimensions: 579x450px
1648.2 In reply to 1648.1
Hi Paul,
Press Ctrl+shift (keep pressed) then select by box.
- manz
1648.3 In reply to 1648.2
woooooohoooooo !!
Thanks Steve ;-)
--Paul
