Help with modeling
 1-4  5-24  25-44  45-60
1633.5
very good idea, i'm with you
1633.6 In reply to 1633.5
Count me in! Great idea.
Leonard (moi3D noob)
1633.7 In reply to 1633.6
Manz
My idea was that the rendering "competition?" would help towards general learning--in fact, comparing "how I did this" rather than "competition"
Anyway, I would be in anything that helps us all to learn.
Brian
1633.8 In reply to 1633.7
I do understand that, but just thinking that we should start by making the model ourself, therefore helping users first with MoI. Rendering can then be made if wanted and info on how that was achieved.
Its just with rendering, there are many different renderer`s being used, and a final render can depend on the resources available to that renderer (such as realistic pre-made materials, which can at times only be available to a license holder of that renderer)
- manz
1633.9 In reply to 1633.3
Hi PaQ,
>>What we did is just take some photos of a simple object, like a toy or something like that.
I was not completely sure which direction to take, but yes, we could all work from a pic of something (to start) very simple, then move on to models that will use the various tools in MoI.
I did have a quick look around the web for a simple toy to build, I thought to start, should we try this?:-
EDITED: 3 Aug 2009 by MANZ
1633.10 In reply to 1633.9
this toy seems to be easy to model no ?
I think that if everybody wants to learn something
the difficult thing of this exercise is to find an object
with a little challenging part to modelling
For your toy, have you got the front and top view ?
Thanks in advance
1633.11 In reply to 1633.10
Hi rickky,
I thought to start with something very simple, really just for simple booleans, navigation and moving objects around. If you have a suggestion (or pics of) for another model, then please post.
It is just a pic I found on the web, there was only the one view. I can make the model and posts other views from that if wanted?
- manz
1633.12 In reply to 1633.11
ok let's begin with this toy
other views are welcome ;)
1633.13 In reply to 1633.12
Heres my quick bit of fun at the exercise. Hope it is of some value.
Brian
EDITED: 30 Dec 2008 by BWTR
1633.14 In reply to 1633.13
And here is my crack at the truck. That was much fun and an easy introduction to most of the tools. Now, I need workflow advice on making more elaborate forms and recessed shapes and surfaces.
A couple of problems I had: 1) I drew a spline using polyline, line and arc, joined them and extruded but could not "skin" the major faces despite checking Caps, trying Planar and rebooting. 2) I was not able to group objects such as the ladder parts or the wheel, cap and axle.
Oops! I just noticed that one of the end surfaces got deleted somewhere along the line.
Added material via VrayForCinema4D.
EDITED: 2 Jun 2008 by NYCL45
Size: 197.9 KB, Downloaded: 34 times, Dimensions: 1432x922px
Size: 88.2 KB, Downloaded: 66 times, Dimensions: 1280x955px
1633.15
Hey that's a great model to start with :)
I'll give a try ... is it me or it seems that the wheels are actually blended into the 'body' ?
1633.16
Hi Everybody
I haven't posted here for a while but noticed you all making a truck. Heres my effort. In terms of problems the only real one I had was with the dowels holding up the ladder. I set the fillet number too high and it caused some sort of error when I converted it to an .obj to import into Carrara for rendering. My fault not Moi's I think as I was rushing and didn't check the model for errors.
1. How it looked in Moi with fillet radius set at 0.4
2. How it looked when converted to .obj
3. How it looked on import to Carrara
4. Final render with fillet radius set to 0.35
Keith
1633.17 In reply to 1633.14
This would usually mean that those different curves were not quite touching each other end-to-end. If you could post a .3dm model file with those curves in it, I could take a look and see if that was the problem or if it was a bug.
1633.18 In reply to 1633.17
Okay, i gave it a try.
I had to do it quite fast because i promised the wife i would do some things around the house, so i cheated with the wood material and painted the car brown instead of texturing it :-)
Edwin
As a final touch, God created the Dutch
Size: 330.9 KB, Downloaded: 100 times, Dimensions: 800x601px
1633.19
Here's my truck!
Rendered with Vray4Cinema4D.
Thanks 4 viewing...I'm eagerly waiting 4 the next challenges, fun and learning!
Dan
"The darker the night, the closer the dawn."
(Buddhist Proverb)
Size: 150.1 KB, Downloaded: 25 times, Dimensions: 800x600px
Size: 360.2 KB, Downloaded: 50 times, Dimensions: 1680x1050px
1633.20
Here's an other version, funny to see all there little moi's truck :)
EDITED: 28 Nov 2013 by PAQ
1633.21
And here's a little rendering, uv's were better than I expected, I didn't change anything o)
EDITED: 3 Feb 2010 by PAQ
Google Sktechup few polys (so cubic wheels :)
render Podium
EDITED: 2 Jun 2008 by PILOU
1633.23 In reply to 1633.17
My bad. I spoke too soon; a redo just now worked fine. It was not knowing when to use the Object Snap. I do now.
Your moi3D is a nifty app and I very much look forward to using it.
Thanks for the response.
Leonard
1633.24
Hi all
Its interesting to see the difference in the renders. The Cinema 4d one looks almost real. I rather liked my Carrara render even though It looks like its all carved from one big log. Are you others using texture maps? Is Cinema 4d much better than Carrara is it just that I'm not doing a very good job of rendering.
Michael I hope you don't mind me using your Moi forum to talk about rendering.
Keith
Show messages:  1-4  5-24  25-44  45-60
