Help with modeling
 1-9  10-29  30-49  50-60
1633.30 In reply to 1633.28
>>I thought I'd 'Pimp my Ride' slightly modified.
Hehe, I love your personal touch!
Dan
"The darker the night, the closer the dawn."
(Buddhist Proverb)
1633.31
I know its mad but I'm going to have a go at this:
http://www.the-blueprints.com/index.php?blueprints/motorcycles/triumph/24435/view/triumph_bonneville_t100_2008/
I'll post back the result in about 6 months.
Keith
1633.32 In reply to 1633.24
Hi Keith,
> Michael I hope you don't mind me using your Moi forum
> to talk about rendering.
Sure, it's totally fine, in fact I'd encourage it.
Certainly a lot of people want to render models after they are done constructing them. It is very much on topic to discuss what you want to do with the model data that you produce using MoI.
1633.33 In reply to 1633.28
Hi Danny,
> Michael is there an easier way to make 'text' follow a curve ?
Nope, sorry - currently there isn't.
1633.34 In reply to 1633.33
A difficult way?
***Modeling Of Ideas***
1633.35 In reply to 1633.34
Hi JTB,
> A difficult way?
The difficult way is just to place each character into position using Transform commands like Move and Rotate.
1633.36 In reply to 1633.35
Keith
Carrara is a fine texturing and rendering app. And, especially, one of the easiest to learn.
I suggest you not even consider another general 3D app untill you are fully conversant with it and, are aware of the full range of options included in it, and budget price plugins available fot it. (Some real frights when you find out what the "big" apps don't include in the basic price!)
Nice to see the great quick modelling that is being done on this thread.
Brian
1633.37 In reply to 1633.35
More like a boring way, not difficult :)
1633.38 In reply to 1633.37
JTB
Your repeated post!
Is this saying anything---loses me?
Brian
1633.39 In reply to 1633.38
I commented Michael's answer... see above :)
1633.40 In reply to 1633.39
I am confused by your addition **Modeling of Ideas*** in each post. It reads as part of your question/answer sentence but I gather it is not?
Brian
1633.41 In reply to 1633.40
Brian,
I believe that is whats known as a 'signature' and not intended to be part of the message / post if you catch my drift?
--Paul
1633.42 In reply to 1633.16
Hi Keith,
>>1. How it looked in Moi with fillet radius set at 0.4
>>2. How it looked when converted to .obj
I am not sure if it related to the fact that MoI will allow an overlap when creating a fillet on a cylinder (that is too big) as I have not seen the problem you mention.
Care is needed when making fillet on a cylinder as it is not allows noticeable when the error I mention does happen.
Simple example:
A cylinder of 3 rad will fillet correctly up to a fillet of R2.99,... a fillet of 3 will fail, but, fillets above that (to a certain size) will be created incorrectly with a surface overlap at the top of the fillet. It is not always obvious, but to show the problem, I have a cylinder of rad 3 with an end fillet of 4:-
- manz
EDITED: 3 Aug 2009 by MANZ
1633.43
Hi All,
I see quite a few have taken part and put forward their own model, nice, I did build the model, but did not texture (attached image).
Any thoughts on what we should build next? Or should I find something a little more interesting that requires the use of more tools within MoI?
- manz
1633.44 In reply to 1633.43
karter
I did grasp the signature idea eventually---it did not seem to appear as such to me--needs a line space !.
Manz
I have started in MoI to do this Jeep Tutorial.
(It may be a bit difficult though)
http://www.cgarena.com/freestuff/tutorials/xsi/jeepmb/index.html
1633.45 In reply to 1633.44
My first try at the Jeep body!
I need to go back to an early point where I made a naughty mistake!
Brian
EDITED: 30 Dec 2008 by BWTR
1633.46 In reply to 1633.45
I think this would be too involved for a group project, maybe if we were retired we could tackle the jeep ;-)
I liked the wooden truck because there was one popping up every day.
I think we should ramp up the challenge with something simple again like the truck with geometric shapes but maybe with some freeform shapes, I'm sure it will keep everyone busy and asking for methods to accomplish a certain feature.
Maybe a certain part on the jeep.
What does the rest of the group think ?
1633.47 In reply to 1633.46
Yes, the Jeep is pull out hair/go bald working!
1633.48 In reply to 1633.47
You should start a new thread, I will join in myself,.. but, a model as you show can be a pain, not only with construction, but also the way you need to build in MoI, as following certain directions can lead to a lot more work due to problems with MoI.
I did forget myself, and started to build the body of the jeep, I constructed (see pic) the outer borders, then shelled, but due to that I am unable to fillet some internal edges to the rads I want, it would need breaking apart and faces rebuilding, so its easier to start again (this I have had to do on a number of models, for various reasons with MoI)
But anyway, if you would like to, start a new thread and lets build the jeep?
- manz
1633.49 In reply to 1633.48
Manz
I tend to get "sidetracked"--needs not me to make a starting pair--to be fair!
Brian
(With the little time left there is just so much about EVERYTHING I want to learn--computer/3D/modelling is just part of the many sidetracks!)
Show messages:  1-9  10-29  30-49  50-60
