Extract Geometry
All  1-8  9-12
1614.9 In reply to 1614.8
Hi Paul, just one other note - if you want to chamfer all the edges on the top there, there is a shortcut for doing that by selecting the top face instead of the top edges.
When you select a face and then do chamfer or fillet, all the edges that belong to that face will be targeted for the operation.
So in cases like this, that is just one thing you have to pick instead of picking all the edges.
But you'll still want to change that anti-aliasing setting, or update your video driver like I described above so that regular selection works properly. Please let me know if you need more info on that.
1614.10 In reply to 1614.7
Thanks for the update and links...
>If you go to your video card settings, under Control Panel / Display / Settings / Advanced, you'll probably >see a section there for >anti-aliasing, is it currently set to have anti-aliasing turned on always? If so >change it to say "application controlled", and that will >probably solve the problem.
Super !!! now were talking :-)
Rgds,
--Paul
1614.11 In reply to 1614.10
Hi Paul, did that fix up the selection problem then?
1614.12 In reply to 1614.11
Hi Michael - Yes that did the trick and MoI works as expected now.....and so far my other CAM apps are not effected.
Thanks very much,
--Paul
Show messages: All  1-8  9-12
