Layers and new release
All  1  2-4
1613.2 In reply to 1613.1
Hi okapi, it won't be much longer before I start on the object organizing system. That's going to be a focus for the second beta.
I've just wrapped up the work on the editing frame, and I have a couple other things I want to add in for the first beta release. So that shouldn't be much longer.
re: export and import capabilities - are there any other specific things that you are looking for in export and import capabilities other than keeping layer/grouping type information in place?
The object organizing system is going to be a pretty big piece of work, it will probably span a few beta releases to work on it. The early ones will probably be focused on just the UI and general approach and not quite have the import/export stuff working yet until the overall approach is finalized.
1613.3
hi Michael,
well one important thing is that the layer structure be kept somehow upon export,
so if exporting OBJ, that the exported meshes are grouped in a similar way as in Moi.
AS far as import goes, this may altogether be another piece of work,
but it would be good to have at least a dxf import (since DWG is propietary), in order to bring in CAD plans into moi.
I know there is a DXF to 3md utility; could this not be automated in moi, so that if one tries to open a DXF in moi,the dxf is transformed into a 3dm file (ideally with layer order), and then opened in moi.
1613.4 In reply to 1613.3
This is exactly my thought as well, except I would like to see both DXF in and DXF out. This would then allow both import and output to and from the 2D CAM softwares I play with. If MoI could handle 2D work in this manner, I would have no use for any other drawing software. Keep up the great work!
JP
Show messages: All  1  2-4
