Perpendiculars objects copies with duplication along path tool
All  1-6  7-9
1605.7 In reply to 1605.6
Maybe like this? ;)
And try to use the flat, none and free form option ;)
In your case free form works but you must draw the first line on the start of the curve!
EDITED: 16 May 2008 by PILOU
1605.8 In reply to 1605.6
Hi Pierre,
The perpendicular line needs to be at the start or end of the control curve (the curve you are going to array along).
If you need to start the array part way along the control curve, then split the control curve at that point (you can split a curve using "trim", but keep the parts)
- manz
1605.9 In reply to 1605.8
Yup, Steve has the answer, you need to place your initial curve at the endpoint of the curve and then it will work as you expect.
Basically the movement and rotation that is applied by array curve starts with an initial reference frame of the start of the curve, then moves that frame as it travels along the curve.
Your curve is at some offset from the starting frame, so you are seeing that same offset applied to each copy.
I can kind of see what you were expecting, but it seems like it would be difficult to adapt the array on curve to work like that. Like for example say you said you wanted 5 copies of that object along that curve. But your object is not at 1/4 of the distance along that curve, so I guess I would make copies starting there and moving along one direction of the curve, but which direction? Right now array on curve avoids this problem by always using the entire extent of the curve.
Show messages: All  1-6  7-9
