How to fix faulty 3dm file?
 1-2  3-22  23-27
1604.23 In reply to 1604.22
I agree, unless you're having problems with OBJs exported from MOI, you should just stick with MOI OBJ exports.
What's the advantage or your reasoning for working with 3DM imports? Unless this is just a test to see how Carrara behaves working with .3DMs?
The only reason I've ever attempted to load 3DM (in XSI I believe), was to try and keep the model in the NURBS domain - if it's going to be converted into polygons anyway, you're then stuck as Michael said with the quality of the target app's importer.
Frankly I'd rather export from MOI and point any problems to Michael (who has a way better history of fixing his code) than now depending on DAZ to fix any issues with their mesher / code...
-Will
1604.24 In reply to 1604.23
one thing i can guarantee is you will NOT be seeing any improvements to Carrara's 3DM import (which i always found to be rather crappy). Working with CAD data is probably very far off of DAZ's radar...
jonah
1604.25 In reply to 1604.21
> ps I presume I am right in that no adjustment to export settings
> for 3DM can actually be done within MoI?
Yes, that's correct - basically .3dm saves the same kind of data that MoI naturally operates on, so there isn't any kind of conversion options when you save to .3dm from MoI.
1604.26 In reply to 1604.25
Thanks all.
One of my reasons for asking these later questioms is just plain curiosty--the need to learn!
Secondly, there is a lot of good 3dm files stuff about and I have been quite happy in importing a lot of it into Carrara in the past.
Thanks for that Carrara import setting advice
1604.27 In reply to 1604.26
For those with Carrara.
Michaels suggestion to move the angle in the Carrara 3dm dropdown to 3 did increase the number of polys and lessened but did not cure the problem as earlier reported.
OBJ, 3DS and lwo seem to be the better imports into Carrara from MoI---I obviously can confirm!
Brian
EDITED: 30 Dec 2008 by BWTR
Show messages:  1-2  3-22  23-27
