VM Ware fusion ???
All  1  2-6
1603.2 In reply to 1603.1
Hi phlatt5th - Rhino uses OpenGL by default for its display, it seems that works better under VMWare, although it may possibly be using a software-only rendering mode instead of hardware accelerated, so you might watch out for that. (The software-only for OpenGL is mentioned here for a slightly different version of VM Ware).
MoI uses Direct3D - VM Ware says it has "experimental" support for that so it sounds like it is kind of a work in progress and may improve in future versions.
I found some release notes for VM Ware fusion here. In one section (under "Gaming with VMware Fusion") it says:
quote:
VMware Fusion now has experimental support for DirectX 9.0 3-D graphics (without shader support) to enable more Microsoft Windows 3-D applications and games to run. This will allow for many new games to run in VMware Fusion that could not be previously run. However, if a game requires shaders it may not run at all. Games that provide the ability to run without shaders can potentially run in VMware Fusion 1.1.
VMware Fusion does not support 3-D acceleration in Unity view. For 3-D applications, use Single Window or Full Screen view.
Note especially the last section. So I don't know how you set it up, but if you can find the settings for using "Single Window" or "Full Screen" view and run MoI in that mode instead of in "Unity" mode, it may have a better shot at working. If that helps, please let me know, others may be interested in that as well.
1603.3 In reply to 1603.2
Also on at least one other version of VMware (VMware Workstation 5.0 instead of the "Fusion" version), you had to explicitly enable Direct3D support, it was off by default.
See here for some details on that and how to enable it. I'm not sure if this is necessary for Fusion or not, but maybe.
Also maybe the amount of video memory presented to the virtual machine may need to be adjusted to be at least 64MB (mentioned here).
1603.4 In reply to 1603.3
Hello Michael,
Since I posted I did some experimenting. I have attached my settings and some screen grabs. I downloaded the VM version 2 beta and tweaked the settings and it worked. I can enlarge any viewport where I could not in version1.1. The array caused it to slow down a bit but still workable. Perhaps these discoveries will be helpful to someone else. I am glad I could get some conceptual work done while I am away from my main workstation. I will check out the links you point me to and will also continue to tweak the settings for optimal work. Thanks for getting back to me.
1603.5 In reply to 1603.2
Michael,
I can report that Moi works in Unity/single window/full screen modes the setting I have posted earlier will show I have alotted 700 mb of memory and 3D is enabled. (Please note the success I have had is with the new VM Ware Fusion beta 2.1) I prefer single window or full screen, seems a bit faster.
1603.6 In reply to 1603.5
A little feedbacK.
Although I am just starting to explore moi3D on a Mac, I can verify that it runs, albeit a might quirky, with VM Ware Fusion 2.1Beta. I tried to make it work with Fusion v1.1.2 but individual viewports or all four viewports would simultaneously go black. It just did not work.
With Fusion 2.1Beta, moi3D's lower right viewport lags on start up. Then for a minute or so after start up, there is a pronounced lag when switching between viewports. Once moi3D gets warmed up, these issues disappear. When loading the Beta initially, several Microsoft warnings popped up about a logo test and strongly recommended stopping the loading and warned of potential problems ahead.
Anyway, I have Daniele's Halogen light fixture tutorial loaded and I am officially into moi3D. It is definitely different from the polygon world of C4D which will, I believe, now share time with moi3D. Anyway, Daniele's video has me psyched and moi3D looks like fun.
Cheers,
Leonard
Show messages: All  1  2-6
