WIP Bluetooth ear piece
All  1-13  14-20
1593.14 In reply to 1593.13
Thanks Brian for the suggestions totally agree with your assesment. Here is another attempt with a dome light and area light added and a color floor. Let me know what you think. Thanks
Size: 376.3 KB, Downloaded: 30 times, Dimensions: 1024x768px
1593.15 In reply to 1593.14
Sorry if I am being critical--part of the learning process!
The background is much more contrast appropriate but you have lost a lot of the fine detail rendering that was in the earlier (last) one.
Was it because of the view angle?
The silver probably is more "correct" but you had some "special" great detail shadings in the blacks before.
Hope that helps.
Brian
1593.16 In reply to 1593.15
I don't take it as being critical appreciate the feedback. Here is another render.
Size: 323.1 KB, Downloaded: 31 times, Dimensions: 1024x768px
1593.17 In reply to 1593.16
You know that is a lot better!
Now, 2 things---maybe.
1. Would adding a little disturbance texture to the greys at the bottom and the ear piece help?
(see attached.)
2. (If that is not sufficient) Can you add a second, soft light, which is "instructed" to shine only on those grey parts--and placed off to one side, ---add more 3D effect to those grey parts? (Giving those greys a 3D look, again as shown a bit on the attached---especially to the ear piece)
3.OR-- Would doing 1. ---AND adding a degree of transparency, just to the ear piece, have a good visual result?
I am having fun--hope it helps!
Brian
EDITED: 31 Dec 2008 by BWTR
1593.18 In reply to 1593.17
AND--another next step, look for a background image that might even better lift the object more into looking 3D?
Again, maybe of the style attached?
And, if you want FREE background images, 750 sets of here!(Probably where this one came from originally)--You may have to join (free)
http://www.renderosity.com/mod/freestuff/search.php?section_id=11&query=Background+Images&sort=relevancy&use_age=no&older_age=&older_units=day&newer_age=&newer_units=day&username=§ion_selector%5B0%5D=11§ion_selector%5B1%5D=-1
1593.19 In reply to 1593.18
Hi Brian, thanks for your feedback especially on the lighting it really helped me take a look backward and look at what was missing. I don't however want to make it more 3d looking I was going more for realistic looking model. I do want to make the rubber ear piece a bit translucent so it will be similar to the actual Motorola device. Thanks again take care.
1593.20
Hi all here is another picture of the back of the unit. Take care
Size: 333.4 KB, Downloaded: 31 times, Dimensions: 1024x768px
Show messages: All  1-13  14-20
