please i need help
All  1-9  10-14
1588.10 In reply to 1588.9
Hi billis, to make the Rhino flow command work, you would use an arrangement like I have attached here.
Note how there are 2 separate curves - one straight line and then just one curved one.
Start by selecting the shape (which you will notice I extruded into a solid). Then run Flow, select the line as the base curve, and then the other curve as the target curve. That will then warp your pattern to follow the curve.
You may also want to experiment with flipping the Stretch=n option on or off.
I hope that might help you - but please realize that this forum is not the right spot for answering questions on how Rhino works. There is a totally different forum dedicated to Rhino located here - that is normally the place you should go to ask questions specific to Rhino.
1588.11 In reply to 1588.10
micahel thank u from ur answer.i unnderstand that u say and i am graitfull for ur time that u have spnend to me
thankssss
billis
1588.12
Thought it would be a challenge and a good tutorial for myself not perfect but...
Thanks for the method Michael. After forming the surface like in your last step I did an offset, then loft between the cutouts then a couple of trim sheets for the sides.
I have a question, is it possible to have like a 'solid offset' I tried extrude but it deforms as it goes around the curvature of the sheet, just a thought I had as I was doing the surface offset.
Danny
EDITED: 27 Mar 2009 by DANTAS
Size: 161.7 KB, Downloaded: 93 times, Dimensions: 860x723px
1588.13 In reply to 1588.12
Hi Danny,
Use "shell" (construct~ offset~ shell)
- manz
1588.14 In reply to 1588.13
Thanks Steve,
I should read The MoI docs more closely. The app I use at work offset and shell are 2 separate functions.
Danny
Show messages: All  1-9  10-14
