CAM Software
 1-5  6-25  26-34
1586.26 In reply to 1586.25
All right, I was going to stay out of this (so many other resources on the web beside the MoI forum), but....
RhinoCam is a plug-in that runs inside Rhino. So you can ctrl-c in MOI and ctrl-v in Rhino and then toolpath. No importing, saving, or anything else. Basic 2d cam is $1k or less. Continuous 4th axis rotary is an add on to the basic 2d, for another $1k. So, you can have honest to goodness, no BS wrapping, 4th axis rotary toolpath in seconds from MoI.
RhinoCams toolpaths are OK, but not too smart. They STILL dont have a spiral toolpath along the axis, its more like a wrapped XYZ raster. However, this is the cheapest way you can get true 4th axis toolpathing as far as I know.
Mecsoft is supposed to be releasing an improved version in June 2008, but they're ignored critical requests for years, so I'm not going to hold my breath for anything groundbreaking.
I think they have a free demo downloadable on their site, but expect a few calls from Anita the salesperson if you put your real phone # in there. ;-)
EDITED: 5 May 2008 by BODINI
1586.27 In reply to 1586.22
Hi Ed,
You may want to look at Meshcam? http://www.grzsoftware.com/
It does have 4 axis (rotary table) and is only $175
There is a 30 day download (fully functional trial).
It is more of a rapid prototype software, but does have pencil (so concave rads can have finish path). I have downloaded to have a play, but no time until later.
There is also a cutter path verification program there (cutviewer) at extra cost, but both together are only $325, so maybe worth a look?(again you can download a full version trial)
- manz
edit:
Just noticed there is limitation on the 4th axis (rotary) in that :-
1. The 4th axis must be parallel to the X axis.
2. The program zero must be on the left-hand side of the stock and along the center of rotation.
EDITED: 6 May 2008 by MANZ
1586.28 In reply to 1586.27
3. It is indexed only (non-continuous).
1586.29 In reply to 1586.28
Hi Nick,
Yes, it is certainly limited, but I have been looking around for reasonable priced software that may be of interest to Ed.
I have also come across Desk_CNC, http://www.imsrv.com/deskcnc/ again limited on the 4th axis, but does have options for rapping on the 4th axis (to x) which is only indexed machining, but may be of interest.
@$250 with demo available.
@Ed
I am not actually sure at this time as to what the revolve of the 4th axis is, is it the actual table, or is it similar to an indexing/dividing head on x/y? (Z being vertical)
- manz
1586.30 In reply to 1586.29
Hi Steve,
I believe Ed's 4th axis lies along the X axis (ie. 90deg to the Z axis spindle) and therefore rotates along that axis also.
Hope thats make sense ?....Unfortunately I cannot help with code for a 4axis job but I hope to have a go with your model as a 3 axis path as soon as I can.
All the best,
--Paul
1586.31 In reply to 1586.30
Hi Paul,
I did think that, but can also see how the table rotation could be seen as at 90 deg from Z (vertical), so asked for verification.
This thread is certainly making my old brain come up to speed (so I thank all for that) with what is available and (possibly) expected.
- manz
1586.32 In reply to 1586.24
Hi Colin,
Just like you i am designing jewelery so,
I'm just curius about the limitations on the
MDX-15 from Roland
If possible could you show one example of
something of a complex piece you have made
on that machine
1586.33 In reply to 1586.32
Hi Paolo,
Here's a link to a previous post I'd made.
http://moi3d.com/forum/index.php?webtag=MOI&msg=490.1
Here's a link to a Gallery with pieces made by MDX-15 users.
Note that the rotary pieces shown in this gallery have been milled using a totally different rotary system than the Fourth Axis Rotary unit that I'm using.
http://www.3dwaxmill.com/phpBB2/album_cat.php?cat_id=1
regards Colin
1586.34 In reply to 1586.33
Colin thank you for the information
I will overlook it with care next days
Future models will be like this example:
EDITED: 24 Oct 2008 by PAOLOLOBBIA
Show messages:  1-5  6-25  26-34
