adjusting the camera's lens length
All  1-3  4-10
1585.4
Thanks Michael...
Brian, the "zoom" is moving the camera's location, but it doesn't affect the amount of perspective distortion... See this screenshot from "modeler R"...
jonah
EDITED: 30 Apr 2008 by JBSHORTY
Size: 75.7 KB, Downloaded: 69 times, Dimensions: 530x833px
1585.5 In reply to 1585.4
Just not a "detail" that I would have thought of any significance in a modelling app?
Brian
1585.6 In reply to 1585.5
It's usually not a big deal unless you have long objects which extend deep into the background. Then the difference becomes quite noticable. Also, it's best to model with the same lens as will be used for your render, especially if you are designing from a perspective image/sketch or you're planning to composite into an existing image.
jonah
1585.7 In reply to 1585.6
Thanks Jonah.
You are saying that, if you plan ahead visually, you can take all the fun out of trying to get things to work properly in the Rendering apps!
Is that where all my time goes???
Brian
1585.8
yes! The other half of time is spent here... :)
1585.9 In reply to 1585.7
Its not like in photography !!!!!!!!!
When using 1000 mm your NOT going to get naked girls automaticaly !
ALTHOUGH MOI 3D DOES DO CURVED SURFACES EASILY ! HAHAHAHAHA ; P : D
1585.10 In reply to 1585.9
Carrara camera goes from 6mm to 500 mm
In my photography days I had lenses for my Minoltas going from 14mm to 1000mm--but they never took 3D!!!!
Show messages: All  1-3  4-10
