Moi & linux
 1-9  10-29  30-49  50
1583.10 In reply to 1583.9
Hi chocobanana, I wish it was as easy as you make it sound! :)
Unfortunately I expect for it to be a very time consuming project to produce such a port, it is hard to estimate it exactly but I would not be surprised at about one year's worth of work to make that happen. Quite possibly even longer.
> This is your best time to consider this seriously since you
> just barely started with MoI.
Well, this is the beginning of my 6th year of full time work into this project. :)
I can understand why you would think that it is just barely started though, I mean making things uncluttered and easier to use often makes people mistakenly think that it only takes a small amount of work to make such things happen... But perversely it actually takes a large amount more work to make such things.
> There's various tools out there that help you make it easy to
> bring it over like QT (now LGPL FYI), Mono and Python perhaps.
Well, these things only tend to make it "easy" if you kind of follow pretty boiler plate standard types of UI... With MoI I've done a lot of customized UI and don't really follow a lot of existing conventions very much, unfortunately that makes it harder to just be able to latch on to one of these existing tools.
> Plus, remember that Linux and Mac OS, especially, are
> taking off in their respective user bases.
Yeah, I definitely agree with you that it would be a great strategic thing to have this! But unfortunately the effort required is just not feasible for me to do right now.
> Perhaps you could find help from someone who could deal
> with the *NIX port.
It's pretty tough to find the right person for this, and I don't think that it would really be possible for another person to do such a large task totally in isolation from me. I mean to do a proper job of porting would mean making a lot of changes to core functions inside of MoI, so it would be a pretty disruptive type of thing, not something that could just easily "glide along" or happen totally aside from my own work on adding features to the existing code base.
So I'm sorry to disappoint you but it is not likely for this to happen anytime soon.
You may want to look into the VMWare, which I believe has software for both Linux and the Mac which will allow you to run Windows programs without having to boot your machine to a different OS. It could possibly solve your problem now.
1583.11
I can't believe in the near feature I will run windows just for MoI (sad)
1583.12 In reply to 1583.10
Way out of my league--but here are my thoughts for what it's worth
I think it is way overdue and time all OS making people/companies made them universally workable.
That programme makers have to design separate products is quite crazy.
What a waste of human resources have been involved!
It's like you were buying an internationally made car but it would only run on fuel from a particular county!
Brian
1583.13 In reply to 1583.11
< I can't believe in the near feature I will run windows just for MoI (sad)
There are another true gems that run only on Pc ;)
1583.14 In reply to 1583.13
Indeed but for first time Apple LOOKS SOLID
Rhino
Siemens NX (that means SolidWorks will have to follow)
Vectorworks
ArchiCAD
Maya
Modo
Cinema 4D
Zbrush
Autodesk - Mudbox (well they had to due to Zbush port on OS X)
3DCoat
Autodesk - Toxik
Apple - Shake
Apple - Final Cut Studio
Adobe - ...etc.
(Solutions to fit all wallets)
1583.15 In reply to 1583.14
Yes, but to be fair - Rhino OSX had been requested for many years, but they never planned to port it. Then someone knocked on their door with a working version in hand... I think Michael is doing right to focus on improving MoI for Windows. Once everything goes 64 bit, will there be any advantage to using OSX anyway?
Brian, if you want to compare software to gasoline then at least you should consider the OS is the type of engine. And the software can be gasoline, ethanol, diesel, hydrogen, etc. Some can be interchanged, and some not!
jonah
1583.16 In reply to 1583.10
Hello Michael
I certainly am well aware that it is a great effort to make the port and that my words didn't make it justice.
I guess this is more like something I wanted to share since I am so frustrated in my quest to free my self of proprietary OSes in an Industrial Design workflow.
Anyway, you got a great point on what concerns the interface, toolkits won't help you here indeed... Perhaps gecko, webkit as discussed before to replace that nasty mshtml... Maybe make this a RIA app? And I personally think you're definitely going on the right path by think of a proper custom interface instead of using a generic concept!!!
Great that you understood what I meant by "barely started". This is still v1 but you'll surely agree now would be the best time to port with the fewest human/technical resources available. And you don't have a manager above you to say no.
But anyway, in the end I understand your whole point for the single fact that this is a single man effort.
Thank you for the tip in running it on a VM. I would rather try everything possible to run in Wine but if necessary I'll resort to a VM.
Btw, is the educational version of MoI upgradeable to a future commercial version?
Thanks and all the best!
EDITED: 16 Jan 2009 by CHOCOBANANA
1583.17 In reply to 1583.10
I totally agree with this Michael. Back when I did interface/interaction design, I always said that if it looked obvious, then I had done my job well. Trouble was people looked at the final result and didn't understand why it took so long.
Keep up the good work.
Tony
1583.18 In reply to 1583.15
Hi Jonah,
I think that he had a kind of prototype cooked up initially there to show what was possible, not really a complete working version.
If I understand correctly, he's been working on getting a full ported version for well over a year now and there is still quite a ways to go yet before it is actually finished!
It looks like there are going to be some pretty big problems with the finished port as well since it won't run any existing plugins or even any existing scripts since those are all done in VBScript instead of a cross-platform scripting language...
1583.19 In reply to 1583.16
Hi chocobanana,
Yeah I think this is the best possibility for the future.
But unfortunately these other engines are way behind in the kind of extensibility that I really need to do a proper job. Mshtml.dll has a mechanism in it called IHTMLPainter that makes it pretty easy to make a C++ component that integrates into the browser at a very low level, participating directly in the painting of the page.
The other web platforms just do not have anything similar to this, they have instead focused energy only on things accessible to script code, stuff like the Canvas element. That's great for other types of stuff, but not really for trying to make custom controls like I need to do.
Hopefully in the future this will get better though. In the most recent version of Qt they brought in a version of WebKit that can be used in conjunction with Qt. I was hoping that this might be a good way forward but I took a look at it and the extension hooks are still too primitive, it does allow for a Qt control to be declared as an <object> tag in a page, so there is something there but the controls that way are kind of like an isolated island, I need better integration into the whole page like the mshtml.dll mechanisms provide. For example I need to be able to put down a custom painted background using C++ code, while letting the browser handle the text display in the foreground - that isn't possible with a clunky <object> method but works great in the IHTMLPainter method in mshtml.dll .
Yeah, I think I will set it up to allow that.
1583.20 In reply to 1583.19
Maybe I should think up a Metafive?
Braian
1583.21 In reply to 1583.18
""""I think that he had a kind of prototype cooked up initially there to show what was possible, not really a complete working version.
- Michael""""
Of course! I didn't mean to imply that it was stable. It was just a baby learning to walk. Take two steps, crash and repeat :) Considering their extensive beta periods, I wouldn't be surprised if it's not ready to ship at same time as V5 for Windows... About the scripting, i think I recently saw Dale mention something about adding new languages. But the plugin port is a pretty major issue. I think they plan to fully expose the feature set of Rhino's internal render engine, because they expect no render plugs to be available right away...
jonah
1583.22 In reply to 1583.21
Hi Jonah,
That may help to give someone who is writing a completely new script an option to choose a language that will be portable.
But it won't help to enable any of the zillions of previously existing scripts to run...
I'd think that any "power users" on the Mac will still need to run the Windows version under Parallels/VMware even after the native Mac port is all complete... That seems like a pretty messed up situation.
1583.23 In reply to 1583.18
that's why the sooner the better will be a wise choice for MoI, IMO
1583.24 In reply to 1583.22
""""I'd think that any "power users" on the Mac will still need to run the Windows version under Parallels/VMware even after the native Mac port is all complete... That seems like a pretty messed up situation.
- Michael""""
That's probably true, but somehow I think only a small portion of users with big investments of plugins will feel the need to jump to OSX. If Win users migrated in a mass wave to OSX, it wouldn't really give McNeel much reason to work on the port in the first place... :) Rhino 5 will be 64 bit. So will there be any benefit to using OSX instead of PC?
jonah
1583.25 In reply to 1583.24
Hi Jonah,
I'm actually not so much thinking about existing users, more about brand new users.
They'll ask a question about how to do something, and the answer will be - "use this plugin" or "use this script", and then they won't be able to do that.
For example they'll go to the Rhino labs page and see all the different plugins that are supposed to help them do various things, but they won't be able to use any of them...
I think most of the OSX users would consider OSX itself to be the main benefit!
But the overall main reason to do a port is to attract more brand new users who are not already using the existing software since it does not run on their operating system, rather than for existing users.
1583.26 In reply to 1583.25
CORRECT
About 60% of the beta users are current Rhino users on Windows. I expect most will want to switch. I don't think we'll attract many non-Rhino users until we have a real Mac OS X interface. Robert McNeel
http://www.architosh.com/news/2008-08/0814_sig_interv_rhino_osx.html
1583.27 In reply to 1583.24
McNeel Explains Leopard and 64-bit Rhino for Mac Users
1583.28
The bottom line is lots of parts have to be reviewed and in many areas they have to go back to the drawing board, BUT if they play their cards well that could ONLY result to a better PC and OSX software.
Anyway that's turning to a RhinoOSX thread, all I'm interested is to MoIOSX here...
1583.29 In reply to 1583.26
Brians Metafive!
MoI is SOOO good!
Throughout the world, users buy new (no name!!!) PC OSs/progs (take your pick of Meta4S) to gain the benefits!
Suddenly, all the PC alternatives find they can provide solutions to "accommodate" MoI working in thier system!
AND!---Michael only had to stick to his guns!
(Has anyone a problem that Brian can not fix in a trice?---I have YEARS of experience in solving the problems of the world!)
Brian
Show messages:  1-9  10-29  30-49  50
