Navigation question-request.
 1-11  12-23
1582.12 In reply to 1582.11
Hi PaQ,
For the toolbar button, you probably want to set the option to reverse how it works, you can do that under Options dialog / View / Rotate/Pan/Zoom options / Reverse rotate button.
The rotate button is set by default to rotate by moving the camera around, like pushing to the left rotates the camera location towards the left. As the camera moves towards the left, objects in the scene will appear to move towards the right. If you enable the "Reverse rotate button" option, it will work more like you rotate objects towards the left when you move towards the left, that may suit you better.
Also with that button you don't want to make large movements with the mouse like you may normally do with the "in viewport" type rotate, just move it by a pretty small amount, like given the size of the button don't move it more than one button's length or so away from there. This can be nice for tablets because you can get action with only small movements of your hand. You can also adjust the sensitivity under that Rotate/Pan/Zoom options to reduce it still seems too sensitive for you.
I have looked at Modo before, but just not in detail at rotation, I'll check it out.
It does seem like MoI's behavior is more standard across a larger number of apps though.
1582.13 In reply to 1582.12
Why would you mention MoI as standard, when you add 2d manipulators/ widgets? Seems a little strange for you to put forward convention.
- manz
1582.14 In reply to 1582.11
Hi PaQ - just did some quick checking of Modo 203.
When using the little toolbar rotate in Modo, it seems to also behave exactly the same as MoI. I mean same exact behavior when you flip upside down.
Here I'm talking about the little one in the upper-right corner of the viewport, are you talking about some different one, or did this possibly change in the new version of Modo?
I do see that the Alt+Left click "in viewport" rotate is totally different than that though. Actually this is the kind of rotation that really bugs me quite a lot, where it doesn't keep me vertically oriented and above the x/y plane when I rotate towards the left. For me that makes me get twisted upside down way more easily than the "stay vertical" type rotation method.
This is the same type of rotation as the "rotate relative to view" option in Rhino.
The option that I was thinking of adding for you is different than this - I was thinking of adding the option to behave like Maya where it works like MoI currently does except if you have rotated "over the top" of the pole so that you are now upside down, it will reverse the left-right action to make it feel more local but still keep you in the "above the plane" type rotation method. This is the method that has the "bounce" effect in it when doing animated style continuous rotations but I think it will make it work more like how you expect.
1582.15 In reply to 1582.13
Hi Steve,
I'm not dead set on breaking convention just for the sake of breaking convention.
If I see some advantage to breaking convention then I'm not very hesitant about doing it, but like in this case PaQ was asking for MoI to work more like other apps, well it turns out that MoI is already working more like other apps in this case. So mentioning convention was definitely applicable to this conversation.
The 2D manipulators are intended to be familiar and use a convention similar to 2D illustration programs that a lot of artists are already familiar with. So adding those in to MoI is not like adding in some alien feature that nobody has ever seen before in any kind of software.
Sure, they haven't seen it before in 3D software, but in many cases 3D software has ignored 2D type methods too much.
1582.16 In reply to 1582.15
Are the Carrara type manipulators to ahead of thier time for 2D apps perhaps?
(I had to--again!)
Brian
1582.17 In reply to 1582.16
No, it is just too weird in a 2D app to put a thing right in the middle of your object with 2 big lines sticking out of it.
Carrara type manipulators are designed for a totally different purpose of manipulating 3D points in a 3D view.
1582.18 In reply to 1582.17
For interest, this is the setup in Amapi 7.52.
The now Universal Manipulator of Hexagon (Carrara) setup, from the same design team, was the next step forward.
Horses for courses, I find going back to the 2d apps methods "wierd"
(I use the 4 views generally for working in all my apps and ---well you know my likes.)
Brian
EDITED: 30 Dec 2008 by BWTR
1582.19 In reply to 1582.18
Hi Brian, I wouldn't mind eventually adding in a universal manipulator method in MoI as an additional / alternative way.
The one really big problem with it is that it goes right on top of your objects, partially obscuring your view of them, instead of going around them leaving your object fully viewable.
In the 2D view, MoI's new editing frame solves that problem and just generally has a lower impact on distracting you from the objects. There are 5 individual translucent grips, no lines connecting them, there is just less stuff on the screen there. That will make it easier to keep it on all the time without it getting in the way as much.
In the 3D view it becomes more difficult to come up with a frame like this that goes around the outside of everything. That's when a design that has a center axis point like the Carrara style manipulator is a good solution. It is a good solution for 3D but not the best solution for 2D.
There are actually some other issues with the manipulator-based approach though - a lot of times they tend to operate in a less precise way by doing things like applying a scale factor just by some arbitrary amount of pixels that you moved the mouse by, instead of being more focused on snapping on to different spots.
For example, MoI's new frame allows for taking this box:
And grabbing the corner of a frame and dragging it up to snap on to the other box above, scaling the inner box by the exact amount needed to make it fit between those areas:
Is it possible to do that with Carrara's manipulator?
1582.20 In reply to 1582.19
Spoil sport!
I though I had good arguments and then you shoot me down!
Story of my life! Cry, mumble, sniff!
Brian
1582.21 In reply to 1582.20
Hi Brian, :) I take it from your reply that Carrara's universal manipulator cannot do that kind of snapped precision scale...
That kind of precision is not generally needed when just squishing vertices around in a poly mesh or subd type modeler, which is where you typically see that kind of manipulator being used.
But MoI is focused in a lot different direction than that, not having stuff like precise snapping would not be quite a good fit for the kind of modeling that MoI is set up for.
1582.22
Hi Michael.
Alright, this is a lot better (for me :))
Well it's more the the fact that the viewport continue rotating when I don't move the mouse anymore disturbing me. but I get you loud and clear, as I'll not use this rotation tool I don't really care ;).
Looks like indeed !
Yes you're right, it reacts like in Moi, my mistake :S (but again, I never use it, I'm a shortcut addict when it's about navigation)
I can ear you :) ... now imagine, it's absolutely the same feeling I have with the actual Moi navigation ;) (maybe because I'm using this method since 10 years :P)
I have a fresh install of my computer here, so I don't have my Rhino LE anymore ... but if it's the same, well I would realllly love to have this option for the viewport rotation.
Well again, the rhino method is probably enough. That's said if it's to please 0.01% of you user database, maybe it's finally not really important.
So thanks Michael for your reading anyway !!!
1582.23 In reply to 1582.22
Hi PaQ,
Yeah, it is a very different style. But that continuing rotation is basically what makes it possible to get stuff to happen with only very small movements of the mouse.
I don't at all mind adding in options for stuff like this, especially if I add it only to the moi.ini file, that has a very low impact and doesn't cause any problems.
I'll see what I can do - at the very least the Maya style option of reversing left/right when you are upside down is very easy for me to do, and would probably help out somewhat (it should deal with the kind of left-right reversal that you were mentioning originally), so I might start with that. The full "relative to view" type motion is kind of a bigger change, that one might take a little longer to get to.
Show messages:  1-11  12-23
