Object frame progress
 1-15  …  56-75  76-95  96-113
1571.96 In reply to 1571.95
Yes, it looks fine. Perhaps, the pivot icon size could be decreased slightly...
I have also noticed that the base point for scaling is a corner of object's bounding box (or center point). Does it mean that when you drag a grip and want to use a "snap to grid" feature, then the snap action actually occurs under an imaginary point (corner of bounding box adjacent to the dragged grip) and not under the grip?
Petr
1571.97 In reply to 1571.96
Hi Petr,
Yup, probably will feel a bit less clunky that way. How about this:
I've gotten more used to the slight smaller corner icons too, I think I will keep those but have the original slightly larger one for the highlighted state.
> the grip?
Yup, the grip is actually slightly to the outside of the actual point that you place when you drag it.
Dragging it is not so much actually placing the corner as it is placing the edge of the new bounding box, since it does a uniform scale (this is the same way that images work in 1.0).
1571.98 In reply to 1571.86
For the pivot point indicator, how about the following - modeled in MoI, of course :-)
A small, white icon that shows where the point is and what it does at the same time...
Size: 40.6 KB, Downloaded: 48 times, Dimensions: 959x871px
1571.99 In reply to 1571.98
Hi Satoribomb, that looks pretty good, thanks! I'm not quite on rotation yet, but I'll take a look at that when I get there.
Ok, I got mirroring working. Here's an example.
Starting with moving the mouse over this corner:
If you click down and start to drag, a little target marker will appear on the opposite side of the shape, shown with the red arrow here:
If you move your mouse over to that opposite side point, it will snap on and do a mirror just as if you had run the mirror command along the edge of the object's bounding box:
So it will be possible to do simple scaling, rotation, and now also mirroring by using the frame grips instead of firing up the full transform commands for those.
Also I've set it up so that holding down shift will do a 2D transform on a 3D volume object, so you can hold down shift and drag on a sphere in the Top view to scale it in x and y but leave z as it is, same as the Scale2D command.
1571.101 In reply to 1571.100
This looks good Michael.
Following on from this idea. How about having the same points on the rotate for snapping at specific degree increments?
I see these defaulting to 90 or 45 degrees but the actual steps could be set in preferences.
What do you think?
1571.102 In reply to 1571.101
I'm not sure but I think I'd like a "angle list" similar to what some illustration apps like ACDSee (previously Deneba) Canvas and others provide.
I typically have my rotation snap angle set to 15 degrees but some apps allow you to specify arbitrary angles; "15,30,45,60,90..." etc.
This lets you specify exact angles instead of a single angle step.
However, having that isn't too important - either way as long as the angle is a user config'd option...
-Will
1571.103 In reply to 1571.102
Hi Will, hi ash - for rotation I was thinking of using the same snap settings as you can currently use for drawing an angled line.
This can be changed under Snaps / Straight snap options / Snap angle, the default is 90 degrees.
Do you think it should be a different setting from that?
1571.104 In reply to 1571.103
As always - give the user the choice if possible :-)
For myself I would probably like the two to be different settings.
1571.105 In reply to 1571.103
"This can be changed under Snaps / Straight snap options / Snap angle, the default is 90 degrees.
Do you think it should be a different setting from that?"
Hi Michael, yeah, I already have mine set to 15 degrees...
I'm fine with it as it is, I guess it's up to you if you want to code in more options - it would be nice of course.
I still can't wait to try out the new frame! :-)
-Will
1571.106 In reply to 1571.105
The thing is, too many options can also cause problems, especially for similar things. For example it can be frustrating if you find a snap angle setting in one spot, and set it, but then the thing you are actually using is controlled by a different snap angle setting somewhere else...
Will, if there was another setting, it sounds like the first thing that you would do would be to set it to be equal to the other kind of angle snap to get them working the same, right?
I think I will make this off of the same setting for now, but if you run into issues where you wish they were separated, let me know and I'll see what I can do.
1571.107 In reply to 1571.106
While working on a document in Photoshop, I've noticed that if you press alt while dragging the corner handles (In free transform) the center widget becomes the origin of the scaling action. This overrides the normal "opposite corner handle" origin.
If a similar gymnastic were possible in Moi, it might be quite interesting...
Marc
1571.108 In reply to 1571.107
Hi Marc, I do have a similar thing set up for this. Except instead of using Alt, you can switch between scale-from-corner and scale-from-center by clicking a corner grip (press and release the mouse button without dragging).
I've got simple rotation working now, just working on a couple of more tune-ups to that. You'll be able to do a rotation of a specific angle by setting the angle constraint in the bottom toolbar either before or during dragging the rotation grip.
1571.109 In reply to 1571.108
Hi Michael, will it be possible to drag the center point elsewhere?
Marc
1571.110 In reply to 1571.109
Hi Marc,
For scaling no, but I think for rotation yes. I haven't quite gotten to that part of the rotation stuff yet though.
All right, well I've finished up the object frame stuff for the first beta.
Some of the interesting additional things - the frame will now show up in the perspective view as well if you have planar objects selected.
When you click (instead of drag) the rotation grip, you go into a special tri-wheel type rotation mode. This is now slightly different than the one in v1 on background images. In the Top/Front/Right views, you will always see a single view-oriented circle there, so that lets you always do a world axis rotation if you use those views. In the perspective view, you see all 3 circles.
When you're in tri-wheel mode, you can grab the center rotation point and move it somewhere else. That moves the entire tri-wheel to a new location and lets you control the rotation pivot point.
It's also possible now to get an exact angle rotation with the rotation grip (or wheel mode) by entering an angle constraint on the bottom toolbar either before or during doing the drag.
This now lets you do quite a lot of things, such as scaling, mirroring, and rotation either freeform or by a specific angle without needing to activate the Transform commands.
Background images also get all the new edit frame stuff as well, so you can toggle between scaling an image from the corner or from the center by clicking on the scale handles, and set the center of rotation in the same way.
1571.112 In reply to 1571.111
Sounds good Michael, can't wait to try it out.
1571.113 In reply to 1571.111
>When you're in tri-wheel mode, you can grab the center rotation point and move it somewhere else. That moves the entire tri-wheel to a new location >and lets you control the rotation pivot point.
My CAM app has the facility whereby you can move the pivot point.....without cluttering the screen. BY holding down Ctrl and RMB clicking the position on screen will do this ?........I will be purchasing MoI very soon and so I look forward to trying your version out.
Thanks Michael,
--Paul
Show messages:  1-15  …  36-55  56-75  76-95  96-113
