Object frame progress
 1-9  …  50-69  70-89  90-109  110-113
1571.90 In reply to 1571.89
Hi Petr,
> Aha... I didn't realize that contrary to background image the
> object is getting squished as you move a cursor towards the
> opposite frame corner.
Well, it is different than the background image if you track along a horizontal line while going over, that will do the 1D non-proportional scale in this case which images don't do.
But really I meant any kind of scaling at all. It would be kind of frustrating if you could get a mirrored and arbitrarily scaled object by dragging over there, but not get a mirrored object of the same size, actually though that seems to be the standard behavior in 2D illustration programs that do allow dragging to the opposite side.
> I think I am not completely clear about this part.
> Do you mean the width of the bounding box of frame (distance
> between grips) or object's bounding box or distance between
> grip and world Y axis?
I mean width of the object's bounding box. In the example I showed the edge of the bounding box happened to be on the world Y axis, so that's all I meant by referring to the Y axis specifically there.
> Will a position of the pivot point (both scale and rotate pivot)
> impact on mirroring itself?
Not for the one that I showed in that previous picture. I would plan to have that available in the same spot and behavior regardless of pivot mode/placement.
However, if you have scale-from-center turned on, I was thinking about having other snap points in the other frame corners so that you could do an exact "in place" mirror (around the center point) by targeting those points.
> Will we be able to identify/change the location of a mirror axis?
Well, it will always be the 2 bounding box edges opposite of the corner that you choose. So the choice of which corner you drag will let you pick between those edges, but there won't be any way to set it to some arbitrary line elsewhere, for that you'll still need to use the regular Mirror command.
> Your illustration includes some point, does the mirror axis (parallel
> to y axis) pass through that point at the end of a curve or is there
> just hard-coded Y-world mirror axis?
The mirror axis will always be the edge of the bounding box, but of course when you have an endpoint of a curve sticking out to one side, then that end will be on the bounding box edge.
> Another question. Is a rotate icon always on the top side of the frame?
> In other words, when I rotate the object using the editing frame, deselect
> it and re-select the same object, does the original frame or new one with
> the rotate icon on the top appear?
If you grab it and rotate it, it will then spin around to some other location, but if you unselect and then reselect, then the whole frame will get reset on the new selection and the rotate grip will be back at the top of the axis aligned frame again.
In order to keep the rotation between selections, I would have to maintain some additional persistent state associated with objects... It could be possible to do that, but it brings up a bunch of issues.
It seems to be pretty common for 2D illustration programs to reset the frame like this, like for example Xara does it after every rotation even if you don't change the selection. Adobe Illustrator seems to try to maintain the frame orientation if you have things like a bunch of rectangles all at the same angle selected, but it too will reset it to world-aligned after every rotation if you have like 2 rectangles at different angles selected at once.
1571.91 In reply to 1571.87
Hi Petr,
> Something like circle with cross mark inside it or two concentric
> circles? Or a red glow around point?
How about this:
1571.92 In reply to 1571.91
Hmmmm....It should go together with a look of grips and rotate icon and reflect that this mark is a center point of rotation as well as a base point for the scale. My original suggestion doesn't seems to fit for representing the base point of scaling.
And what about a small square with cross inside like window manager's close button?
Petr
1571.93
a while back I came across this, on the topic of a "3D Gizmo", and noticing the current thread I thought you'd enjoy knowing about it, and possibly comparing it to what's ahead in v2's plans.
The first link is there simply as general FYI; please, take special note on the second, at the bottom portion of the page under the heading "Publications", there's a reference to the Kite Geometry Manipulator:
http://www.ds.arch.tue.nl/Research/Projects/E3DAD/
http://www.win.tue.nl/~spranovi/research.htm
Cheers,
- Diego -
1571.94 In reply to 1571.93
The Kite looks half way to being like the Carrara/Hexagon maipulator!
(I had to say that!)
Brian
1571.95 In reply to 1571.92
Yeah, that is a good idea that it should match the other grips, especially since you'll be able to grab it in one case for moving the rotation center.
How about this:
1571.96 In reply to 1571.95
Yes, it looks fine. Perhaps, the pivot icon size could be decreased slightly...
I have also noticed that the base point for scaling is a corner of object's bounding box (or center point). Does it mean that when you drag a grip and want to use a "snap to grid" feature, then the snap action actually occurs under an imaginary point (corner of bounding box adjacent to the dragged grip) and not under the grip?
Petr
1571.97 In reply to 1571.96
Hi Petr,
Yup, probably will feel a bit less clunky that way. How about this:
I've gotten more used to the slight smaller corner icons too, I think I will keep those but have the original slightly larger one for the highlighted state.
> the grip?
Yup, the grip is actually slightly to the outside of the actual point that you place when you drag it.
Dragging it is not so much actually placing the corner as it is placing the edge of the new bounding box, since it does a uniform scale (this is the same way that images work in 1.0).
1571.98 In reply to 1571.86
For the pivot point indicator, how about the following - modeled in MoI, of course :-)
A small, white icon that shows where the point is and what it does at the same time...
Size: 40.6 KB, Downloaded: 48 times, Dimensions: 959x871px
1571.99 In reply to 1571.98
Hi Satoribomb, that looks pretty good, thanks! I'm not quite on rotation yet, but I'll take a look at that when I get there.
Ok, I got mirroring working. Here's an example.
Starting with moving the mouse over this corner:
If you click down and start to drag, a little target marker will appear on the opposite side of the shape, shown with the red arrow here:
If you move your mouse over to that opposite side point, it will snap on and do a mirror just as if you had run the mirror command along the edge of the object's bounding box:
So it will be possible to do simple scaling, rotation, and now also mirroring by using the frame grips instead of firing up the full transform commands for those.
Also I've set it up so that holding down shift will do a 2D transform on a 3D volume object, so you can hold down shift and drag on a sphere in the Top view to scale it in x and y but leave z as it is, same as the Scale2D command.
1571.101 In reply to 1571.100
This looks good Michael.
Following on from this idea. How about having the same points on the rotate for snapping at specific degree increments?
I see these defaulting to 90 or 45 degrees but the actual steps could be set in preferences.
What do you think?
1571.102 In reply to 1571.101
I'm not sure but I think I'd like a "angle list" similar to what some illustration apps like ACDSee (previously Deneba) Canvas and others provide.
I typically have my rotation snap angle set to 15 degrees but some apps allow you to specify arbitrary angles; "15,30,45,60,90..." etc.
This lets you specify exact angles instead of a single angle step.
However, having that isn't too important - either way as long as the angle is a user config'd option...
-Will
1571.103 In reply to 1571.102
Hi Will, hi ash - for rotation I was thinking of using the same snap settings as you can currently use for drawing an angled line.
This can be changed under Snaps / Straight snap options / Snap angle, the default is 90 degrees.
Do you think it should be a different setting from that?
1571.104 In reply to 1571.103
As always - give the user the choice if possible :-)
For myself I would probably like the two to be different settings.
1571.105 In reply to 1571.103
"This can be changed under Snaps / Straight snap options / Snap angle, the default is 90 degrees.
Do you think it should be a different setting from that?"
Hi Michael, yeah, I already have mine set to 15 degrees...
I'm fine with it as it is, I guess it's up to you if you want to code in more options - it would be nice of course.
I still can't wait to try out the new frame! :-)
-Will
1571.106 In reply to 1571.105
The thing is, too many options can also cause problems, especially for similar things. For example it can be frustrating if you find a snap angle setting in one spot, and set it, but then the thing you are actually using is controlled by a different snap angle setting somewhere else...
Will, if there was another setting, it sounds like the first thing that you would do would be to set it to be equal to the other kind of angle snap to get them working the same, right?
I think I will make this off of the same setting for now, but if you run into issues where you wish they were separated, let me know and I'll see what I can do.
1571.107 In reply to 1571.106
While working on a document in Photoshop, I've noticed that if you press alt while dragging the corner handles (In free transform) the center widget becomes the origin of the scaling action. This overrides the normal "opposite corner handle" origin.
If a similar gymnastic were possible in Moi, it might be quite interesting...
Marc
1571.108 In reply to 1571.107
Hi Marc, I do have a similar thing set up for this. Except instead of using Alt, you can switch between scale-from-corner and scale-from-center by clicking a corner grip (press and release the mouse button without dragging).
I've got simple rotation working now, just working on a couple of more tune-ups to that. You'll be able to do a rotation of a specific angle by setting the angle constraint in the bottom toolbar either before or during dragging the rotation grip.
1571.109 In reply to 1571.108
Hi Michael, will it be possible to drag the center point elsewhere?
Marc
Show messages:  1-9  …  30-49  50-69  70-89  90-109  110-113
