Deselect Problem
All  1-5  6-11
1552.6 In reply to 1552.4
You could customize and add extra de-select buttons.
As example, in the lower area add a de-select all button, or a row of (as in simple example) red icons,
then when clicked will de-select all. You could also add the same on the right side.
The icons could be the same color as the background, so you could have them fully hidden.
Would that help?
- Steve
EDITED: 3 Aug 2009 by MANZ
1552.7 In reply to 1552.6
Steve
Except for the "you could" start it sounds a good idea in the short term though if all the empty areas of the right hand and lower areas could be that in V2 would be good.
I was quite amazed at working on the boat at how often--every few minutes, that the problem came up. I would click ,incorrectly, on one of many shapes that were faintly visible. I guess I will have to force myself to have the keyboard up on the desk with my left hand hovering over it. I was surprised at how my work flow slowed down.
1552.8 In reply to 1552.7
Hi Brian, Hi Steve, I should be able to cook up something for you that will do that, I mean will deselect if you click in an empty area of the UI. I'll see about that a while later on tonight.
1552.9 In reply to 1552.8
Wow! (again!)
1552.10 In reply to 1552.9
Hi Brian, I think this should do it.
Take the attached SidePane_deselect.zip file and unzip it to get a new SidePane.htm, copy this over top of the old version in the \ui subfolder in MoI's main installation folder. You may want to make a backup copy of the old version so you can restore it in case something doesn't work right.
With this in place, then you should be able to click in an empty area of the side pane to deselect objects. Try the area above "Draw curve", or the area at the very bottom.
1552.11 In reply to 1552.10
Brilliant Michael, thankyou.
It's is so much easier/natural to work with.
I could almost cry as such magnificent help!
Brian
Show messages: All  1-5  6-11
