ui
All  1-8  9-11
1551.9 In reply to 1551.8
This is a stupid question...I don't know if I missed it in the discussion, but I wish the file name was along the top or bottom. When it's on the right, it gets cut off. I sequentially name my files as I create new versions. So I only see the beginning and don't see the number.
Is there a way to get the file name in a different position where the full name is visible?
1551.10 In reply to 1551.9
Hi Phil, if you pause your mouse over top of that filename, a tooltip should pop up with the full filename in it, so that may help.
I have also attached here a tweaked verison of the UI that should show the full filename, breaking it and wrapping it to multiple lines if necessary.
To install it, unzip it to get a new SidePane.htm file and copy it over top of the old version in the \ui subfolder in MoI's main installation folder.
1551.11 In reply to 1551.9
quote:
If you want to get the full path for a file where only the filename is showing, you can pause your mouse over top of the name to see a tooltip with the full path in it. This works for the "current" file name displayed in the upper-right corner of the screen, as well as any file names that were shortened in the File menu / recent files list.
http://moi3d.com/forum/index.php?webtag=MOI&msg=1312.2
Show messages: All  1-8  9-11
