ui
All  1-7  8-11
1551.8 In reply to 1551.7
Hi lyes, I'm glad you found something that works for you.
What you show there with the command set at the top is actually one of the older designs that I had at one point during development, before even the first beta release.
I decided to abandon that method because even though it prevents shifting, it causes the different available options to be sometimes located very far away from the launching button. I felt it made it too easy to not even notice them.
It's not bad with the stuff for Draw curve at the very top of the side pane, but as you have buttons further and further down below on the side pane, it starts to become a larger and larger distance to travel up to get the different options within the command set.
1551.9 In reply to 1551.8
This is a stupid question...I don't know if I missed it in the discussion, but I wish the file name was along the top or bottom. When it's on the right, it gets cut off. I sequentially name my files as I create new versions. So I only see the beginning and don't see the number.
Is there a way to get the file name in a different position where the full name is visible?
1551.10 In reply to 1551.9
Hi Phil, if you pause your mouse over top of that filename, a tooltip should pop up with the full filename in it, so that may help.
I have also attached here a tweaked verison of the UI that should show the full filename, breaking it and wrapping it to multiple lines if necessary.
To install it, unzip it to get a new SidePane.htm file and copy it over top of the old version in the \ui subfolder in MoI's main installation folder.
1551.11 In reply to 1551.9
quote:
If you want to get the full path for a file where only the filename is showing, you can pause your mouse over top of the name to see a tooltip with the full path in it. This works for the "current" file name displayed in the upper-right corner of the screen, as well as any file names that were shortened in the File menu / recent files list.
http://moi3d.com/forum/index.php?webtag=MOI&msg=1312.2
Show messages: All  1-7  8-11
