Modeling a cell phone : Sony Ericsson T650i
 1-11  12-26
1540.12 In reply to 1540.11
Hi sayd, I'm sorry I'm not really following along very well with what you are describing here.
Are you still having problems here?
At one point you seemed to be asking about filleting these 2 edges only:
Generally that's not possible to fillet just a couple of edges out of a smooth edge group like that.
To attempt it would mean creating something like this:
You can see there that the red circled areas would be a kind of hole or gap that would be created in the model if you tried to only cut away just that small area of the model, part of filleting involves removing material...
So I don't quite understand what you were asking for in this case.
1540.13 In reply to 1540.12
Nevermind michael, it already got solved. :)
Now im asking myself how to create the speaker and the keyboard. Due to the lighting effects, i guessed i cut out the grid for the keys to get a plane under it , so i can later create the emissive lightning texture.
1540.14 In reply to 1540.13
Short update:
Made the button:
Size: 123.2 KB, Downloaded: 45 times, Dimensions: 1440x866px
1540.15 In reply to 1540.13
Hi sayd,
Yes, I would do it that way. I would boolean out the numbers/letters and make them too deep so a plane can be put in place for the texturing.
EDITED: 3 Aug 2009 by MANZ
1540.16 In reply to 1540.15
How would you create the earpiece grid? boolean too?
1540.17 In reply to 1540.16
Which part? Do you mean the grid on the back of the phone?
The detail does depend on what the model is needed for. If you are creating the model to then make close renders, then I would say to add as much detail as possible. But if it is going to used as a prop in a scene, then small detail can be added with texture maps.
1540.18 In reply to 1540.17
yes, i do wanna make close up renders.
I attached a pic where you can see what i mean. Would be grateful if you let me know, how you would do this.
Size: 108.6 KB, Downloaded: 59 times, Dimensions: 600x1496px
1540.19 In reply to 1540.18
make one cross module, then use the Array Grid X* Y!
1540.20 In reply to 1540.19
Could you please explain that a little bit more? Im still struggling with the array tool.
1540.21 In reply to 1540.18
Hi sayd,
I had not seen that detail on the pics, so sorry for my confusion.
You will need to create a separate part for that, as you have already boolean out that ear piece.
There are different ways to construct the grid, by either creating a solid shape then boolean out the holes, or by creating the cross sections and boolean them together, or you could even draw the full shape (with holes) and then extrude.
I decided to make the cross sections out of long cubes, I made 2 that crossed each other, then made straight array (which made the needed copies), then boolean together.
1540.22 In reply to 1540.20
The array tool I used for this was the Dir (direction)
I first created 2 long cubes and rotated as needed:
Then selected Array/ Dir
Place the number of copies (top right)
Then select a base point and move the cursor in the direction you want the copies to be made.
1540.23 In reply to 1540.20
The Grid Array is slight different.
First you will have the object to Array:-
Select the Grid Array
Enter the number of copies (how many you want in each direction)
Then enter the spacing:-
OR, use the pointer to set the distance
When done, the Array is made.
Works also with the grid :)
Hum hum ! Boolean union don't works???
(cool for render but in Moi lines don't disapear?
EDITED: 15 Apr 2008 by PILOU
Size: 14.2 KB, Downloaded: 22 times, Dimensions: 414x369px
1540.25 In reply to 1540.24
Thanks guys, i will try this asap!
short update:
EDITED: 15 Apr 2008 by PEBBL
Size: 125 KB, Downloaded: 29 times, Dimensions: 1440x866px
Size: 157.5 KB, Downloaded: 31 times, Dimensions: 1440x866px
1540.26 In reply to 1540.25
Update: Added outer keys
Size: 151.7 KB, Downloaded: 41 times, Dimensions: 1440x866px
Show messages:  1-11  12-26
